how to wire up electronic ignition? #201713
01/23/09 07:26 AM
01/23/09 07:26 AM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
I have a streetrod project here that i want to convert to electronic ignition. I was planning to pull the parts from a 74 dart. i was wondering if anyone had a diagram of the wiring so i could cut it out of the dart and wire it into my streetrod project?
thanks
Re: how to wire up electronic ignition? [Re: dirt] #201714
01/23/09 09:24 AM
01/23/09 09:24 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Check the tech archives. They have a few daigrams you can print out
Re: how to wire up electronic ignition? [Re: Mr.Yuck] #201715
01/23/09 10:16 AM
01/23/09 10:16 AM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
MP sells a brand new wiring harness for the electronic ignition for $20. I highly recommend it.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: how to wire up electronic ignition? [Re: dirt] #201716
01/23/09 05:03 PM
01/23/09 05:03 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Hear some
Re: how to wire up electronic ignition? [Re: Dodgem] #201717
01/23/09 05:05 PM
01/23/09 05:05 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
2
Re: how to wire up electronic ignition? [Re: Dodgem] #201718
01/23/09 05:06 PM
01/23/09 05:06 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
3
Re: how to wire up electronic ignition? [Re: Dodgem] #201719
01/23/09 05:09 PM
01/23/09 05:09 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: how to wire up electronic ignition? [Re: Dodgem] #201720
01/23/09 09:34 PM
01/23/09 09:34 PM
warfordsburg, PA
dirt Offline OP
dirt  Offline OP
warfordsburg, PA
thanks! that helps a ton!
Re: how to wire up electronic ignition? [Re: goldduster318] #201721
01/23/09 10:07 PM
01/23/09 10:07 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
If you use the new mp harness, you only have to make one connection.
The other 3 leads that are used, are already premade with the proper ends. 2 for the distributor pickup, and 1 for the coil -.
The one you connect yourself is the blue wire, and it goes to 12v key on power.
You're done the harness install in 5 minutes.
