1991 D250 turn signal issue. #2016960
02/21/16 11:32 PM
02/21/16 11:32 PM
dusterguy Offline OP
My newly acquired D250 truck has no rear turn signals. Fronts work as normal. I don't want to probe holes in the wires to test for power in the main harness coming out of the firewall. Is there a good way to test the multi-function switch? Any help would be appreciated.
Re: 1991 D250 turn signal issue. [Re: dusterguy] #2016963
02/21/16 11:35 PM
02/21/16 11:35 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Do you have brake lights?
Re: 1991 D250 turn signal issue. [Re: stumpy] #2018029
02/23/16 01:40 PM
02/23/16 01:40 PM
No. No power for brake lights either.
Re: 1991 D250 turn signal issue. [Re: dusterguy] #2019953
02/26/16 01:29 AM
02/26/16 01:29 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Just slide a paper clip or cotter pin into the connector along side the wire and test for power.
