KB hyper piston #362 CH/quench pad height Q #201689
01/23/09 02:48 AM
01/23/09 02:48 AM
RapidRobert Offline OP
Kb hypereutectic piston(s). CH is listed at 1.675" & the flat quench pad above the valve notches is ~.035" higher than the circular pad surrounding the dish. Is the CH dimention to the flat circular area surrounding the dished recess in the center or from pin centerline to the top of the quench pad. Thank you for your time.
Re: KB hyper piston #362 CH/quench pad height Q [Re: RapidRobert] #201690
01/24/09 10:12 AM
01/24/09 10:12 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
The 1.675 will be pin center to the flat of the piston the .035 Quench pad will be from there up.
Re: KB hyper piston #362 CH/quench pad height Q [Re: Dodgem] #201691
01/24/09 10:35 AM
01/24/09 10:35 AM
Thanks Bro
