Re: 1970 Holley Carburetor 383 4 BBL Factory Vacuum Level
[Re: DPS_1]
#2016793
02/21/16 08:37 PM
02/21/16 08:37 PM
RapidRobert
This is the original carburetor, Any suggestions? What is your initial? Is everything (esp the cam) stock? and how mild/wild a com is it? Are you on ported and what is the lowest hot idle speed it will idle at (& is it a stick or auto? & if auto is that in gear/foot on the brake (or ebrake on).
[Re: DPS_1]
#2016796
02/21/16 08:40 PM
02/21/16 08:40 PM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
Iron head 383, 9.6cr, very close to stock cam, exhaust manifolds= Steady 19" manifold vacuum. I've heard people claim as high as 24" but that seems too high.
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: R70RUNNER]
#2016801
02/21/16 08:45 PM
02/21/16 08:45 PM
RapidRobert
that is real good vacuum. what is the initial/are you on ported/lowest idle speed you can get/is that in drive or in neutral
[Re: DPS_1]
#2016814
02/21/16 09:02 PM
02/21/16 09:02 PM
R70RUNNER
Riverside, Ca
Initial 16* 34* all in at 2800, vacuum plugged, with vacuum attached I'm set at 30* drive idle 750rpm. Neutral 850
Recently installed an FBO distributor advance limiting plate.
[Re: R70RUNNER]
#2016836
02/21/16 09:19 PM
02/21/16 09:19 PM
RapidRobert
I know Don @ FBO is a manifold vac afficionado. Not me, tho I have heard good regarding it from some people & I admit I just ain't never worked with it to honestly evaluate it. Your numbers all sound good except I could see the 30 initial on manifold giving some idleing problems. What I would do is go to ported & set the initial at 16-18 (& confirm you ain't into manifold vac at your idle speed & it sounds like you are already good on that) then set the plate to 36 or 38 total (initial+plate) then plug in the can
[Re: DPS_1]
#2016894
02/21/16 10:17 PM
02/21/16 10:17 PM
RapidRobert
I cant say that there IS a vac spec. I've heard that the PV should be half of your idle vacuum (from Holley iirc) and I've heard that you want the PV several in hg numbers below what your idle vac is (to me that seems like you'd be in the power circuit almost all the time). First we need to find out if it is blown: if it is idling low enough that you ain't in the transition slots then you can turn the mini idle mixture screws on the side of the metering block in CW & if it dont die then the PV is indeed blown. I would (1) find out if the current one is blown (2) get the initial finalized (amt/ported or non ported (3) note the vac at that point (at your hot in Drive idle speed which is what you will be at stoplight to stoplight) (3) If the PV is bad (or good) decide what PV # you want & if good if you want to change it. (& maybe someone has a # for you per your request). EDIT you definitely need more than 10 initial right now no matter what (I had 18 on my bone stock '83 318 DD)
