Rear window support #2016605
02/21/16 02:35 PM
02/21/16 02:35 PM
Great Neck,LI,new york
hemi-itis Offline OP
I got bit by Jennie Craig whistlingOne of the things on the bucket list is removing the rear window regulators.So my question is,,,how have you guys supported the window after gutting the regulator.I was also thinking about plastic side windows.Your opinions please scope
Re: Rear window support [Re: hemi-itis] #2016740
02/21/16 06:52 PM
02/21/16 06:52 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Do you still want them to go up and down? If not you could whittle a wood block out of some 1/4 round or similar, put it into the window track and run a screw thru it.
If you still want it to go up and down, old school seat belt pull?
Kevin
Re: Rear window support [Re: hemi-itis] #2016756
02/21/16 07:34 PM
02/21/16 07:34 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Piece of cake. Cut the 1/8" Lexan to same shape as the glass. Drill a 1/4" hole through the inner body structure. Place the Lexan in the opening to locate the spot drilled in the body. Drill a hole in the bottom of the Lexan. Use 1/4" threaded rod with nuts on either side through the body and lexan to attach. This allows the Lexan to be adjusted outward against the outer catwisker to fit nice. You could use 1/4" Lexan but Lee may give you a weight ticket,LOL. For what it's worth 1/8" Lexan fits in the stock weatherstrip for the back glass with no issue.
Doug
Re: Rear window support [Re: hemi-itis] #2017066
02/22/16 01:42 AM
02/22/16 01:42 AM
Thanks DOUG!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Rear window support [Re: hemi-itis] #2017075
02/22/16 01:51 AM
02/22/16 01:51 AM
MR_P_BODY Offline
MR_P_BODY  Offline
On my old 62 Dart I just pinched the tracks
just below the glass with a set of channel locks
that was quick and simple(that was with the stock
glass)
wave
Re: Rear window support [Re: hemi-itis] #2017598
02/22/16 07:21 PM
02/22/16 07:21 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
That really is the wrong end to cut weight.
I pulled out the window glass, the regulators, the trunk hinges and a lot of other stuff when I tubbed my '68 Coronet. Taking weight off the back does not help traction.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Rear window support [Re: Polarapete] #2018088
02/23/16 03:22 PM
02/23/16 03:22 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Not every application wants the same thing...
Get the weight down, then shift what's left around to get the balance where it needs to be.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
