another k frame id #2016340
02/20/16 11:14 PM
02/20/16 11:14 PM
jersey shore
flypaper Offline OP
I hate Texas
flypaper  Offline OP
I hate Texas
jersey shore
i have no clue what this came from? help
Re: another k frame id [Re: flypaper] #2016426
02/21/16 01:19 AM
02/21/16 01:19 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Code/numbers on the front ???
Re: another k frame id [Re: flypaper] #2016438
02/21/16 01:43 AM
02/21/16 01:43 AM
AndyF Offline
AndyF  Offline
Looks like a E body or B2 with a V8. Has the pad style mounts and the double shear idler arm mount. Get it hot tanked and you might be able to read some numbers on it or find the coin welded on the front.
Re: another k frame id [Re: flypaper] #2016439
02/21/16 01:44 AM
02/21/16 01:44 AM
jersey shore
flypaper Offline OP
I hate Texas
flypaper  Offline OP
I hate Texas
jersey shore
i will have to get them tomorrow
the car it came off of i know it doesn't belong to it.
Re: another k frame id [Re: flypaper] #2016442
02/21/16 01:47 AM
02/21/16 01:47 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
68-9 B-body. Doesn't have the 66-7 idler arm mount or the 70-2 sway bar notch.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: another k frame id [Re: moparmarks] #2016459
02/21/16 02:19 AM
02/21/16 02:19 AM
jersey shore
flypaper Offline OP
I hate Texas
flypaper  Offline OP
I hate Texas
jersey shore
thats what i thought it was
it has no coin
what sort of threw me off is this feature
that i think someone added..
Re: another k frame id [Re: screamindriver] #2016476
02/21/16 03:19 AM
02/21/16 03:19 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Is that a slant six unit ?
Re: another k frame id [Re: flypaper] #2016921
02/21/16 10:44 PM
02/21/16 10:44 PM
jersey shore
flypaper Offline OP
I hate Texas
flypaper  Offline OP
I hate Texas
jersey shore
its not a slant k frame
it had a 440 mounted on it when i got it.
i suspect Mark is correct as the numbers i got off it today was
SO 133
with SO on the frame
i suspect it was coded for the 133 day of 68
Re: another k frame id [Re: flypaper] #2016927
02/21/16 10:49 PM
02/21/16 10:49 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Definitely NOT for E body or after 70 year. No provisions for the sway bar to go thru the middle of it. Mounts look like small block to me. I do not see any bolt holes for the sway bar to have been on the front if it was a big block K member.
Just a guess since no Number tag on the front.
Jerry
Old Geezer Racing
Re: another k frame id [Re: SCATPACK 1] #2017170
02/22/16 03:52 AM
02/22/16 03:52 AM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Jerry
I think I can see holes on front edge for the sway bar mount?? Was it on a car when you got it? A or B-body?
Re: another k frame id [Re: flypaper] #2017306
02/22/16 12:40 PM
02/22/16 12:40 PM
jersey shore
flypaper Offline OP
I hate Texas
flypaper  Offline OP
I hate Texas
jersey shore
It was on a 69 b body
I doubt it was original to that car.
Re: another k frame id [Re: flypaper] #2017361
02/22/16 02:00 PM
02/22/16 02:00 PM
fredericksburg,va
fredericksburg,va
Maybe not to that particular car but still 68-69
#1- engine frame mounts are correct for those years 273-440 are the same, Hemi different
#2- sway bar changed in 70 to inside frame, b-e body, holes are in all of them either way,
#3- double shear idle arm mount, this is the only thing that could change years, not sure what year that started, I never had a 66-67 car, 65 and down are totally different.
Re: another k frame id [Re: flypaper] #2017389
02/22/16 02:39 PM
02/22/16 02:39 PM
jersey shore
flypaper Offline OP
I hate Texas
flypaper  Offline OP
I hate Texas
jersey shore
Let me clarify a little
I got it off a a12 superbee
So definitely not from the car
It came from.
Re: another k frame id [Re: flypaper] #2017482
02/22/16 04:46 PM
02/22/16 04:46 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Frank , I can't see the picture here at work, can you add it to the post as an attachment ?
Re: another k frame id [Re: flypaper] #2017552
02/22/16 06:32 PM
02/22/16 06:32 PM
fredericksburg,va
fredericksburg,va
It came from.
Why not? Your reason being?
Re: another k frame id [Re: flypaper] #2017563
02/22/16 06:37 PM
02/22/16 06:37 PM
jersey shore
flypaper Offline OP
I hate Texas
flypaper  Offline OP
I hate Texas
jersey shore
John
i tried
it won't let me do it because they are too big.. rant
Re: another k frame id [Re: cudaman1969] #2017570
02/22/16 06:47 PM
02/22/16 06:47 PM
jersey shore
flypaper Offline OP
I hate Texas
flypaper  Offline OP
I hate Texas
jersey shore
It came from.
this is a correct k frame for a 69 a12 car
you made me dig this pic up from the past here.
the one i have is obviously different. laugh
i have another thread going
with a couple of those k frames in it i suspect.
Re: another k frame id [Re: flypaper] #2018090
02/23/16 03:23 PM
02/23/16 03:23 PM
fredericksburg,va
fredericksburg,va
Interesting, my RR had the first k-frame pictured, never knew what month it was made, who cared about that back then. Guess they made the change over to new k late in the model year but still had a lot of sway bars to use up. What was the first and last build dates for the A-12 cars? Did they use the same frame on all of them?
Re: another k frame id [Re: cudaman1969] #2018107
02/23/16 03:59 PM
02/23/16 03:59 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I never paid attention to the Pilot bee as to the style of K on it. My 69 Bee with an SPD of 2/10 has the 68 style bottom , so the change over was after that.
As far as the comment of using up swaybars ???? The swaybar change happened for the 1970 model year , 69 model year cars would not have gotten them. The K was obviously changed before the model year started in preparation for the upcoming change.
Re: another k frame id [Re: JohnRR] #2018265
02/23/16 08:11 PM
02/23/16 08:11 PM
fredericksburg,va
fredericksburg,va
The last k-frame shown has the holes for the early s-bar drilled not the 70 up, so they where using up what early s-bars they had, my reasoning.
