1970 a100 running great then bad then back again, now meltedwires #2016143
02/20/16 04:54 PM
02/20/16 04:54 PM
kauai
maxi333 Offline OP
maxi333  Offline OP
kauai
70k original 318 ran great then started missing and backfiring, points seemed to be going out of adjustment, re-adjusted to .017, ran well again for awhile them started running , missing backfiring but would then start running well again.
Checked wires, vac leaks, fuel, spark... replaced dizzy n intermediate shaft n bushing, coil, alt, start relay, ballast, plugs/wires, starter, 4brrl carb, intake, valve job, fuel filter, exhaust, really good tune up. Ran great, put a good 100 miles on it then started running really rough again, missing, backfiring... after a bit of that is start running well again, did that a couple times then finally limped it off the highway checked some wires, points, timing, in between starting it when it finally burned up the wrote running from the alt to the start relay up the wiring harness toward the dash. Was it a wiring issue the whole time?
Any help would be great as this is driving me insane lol
1962 Chrysler 300 convertible 383/727
1970 Dodge A108 Boogie Van 318/727
Re: 1970 a100 running great then bad then back again, now meltedwires [Re: maxi333] #2016169
02/20/16 05:50 PM
02/20/16 05:50 PM
NC
1970A66 Offline
1970A66  Offline
NC
I would think it was a wiring issue all along.
Wouldn't think any tune up related item failing could cause the wiring to burn up........
I'd start at the bulk head connector (assuming you have one) and pull the connectors off and look for corrosion, loose and over heated terminals.
Re: 1970 a100 running great then bad then back again, now meltedwires [Re: maxi333] #2016171
02/20/16 05:58 PM
02/20/16 05:58 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Check the amp gauge for loose wires or shorted out. Then bypass the amp meter and add a volt meter instead.
Re: 1970 a100 running great then bad then back again, now meltedwires [Re: maxi333] #2016191
02/20/16 06:44 PM
02/20/16 06:44 PM
kauai
maxi333 Offline OP
maxi333  Offline OP
kauai
So it was probably some ground issue from the start? Arr lol
Re: 1970 a100 running great then bad then back again, now meltedwires [Re: maxi333] #2016286
02/20/16 09:17 PM
02/20/16 09:17 PM
Not a wiring issue that caused the orig part time misfiringprob but it does have a wiring issue now either full fielding (check charging voltage) or there is a dead short or very high (improper) draw (likely) under the dash that is drawing excessive current & burning the wiring. I must admit this is the most discombobulated symptomology I've ever ran into! If the condensor is still hooked up to the coil (should be on positive side if it is there) I'm gonna go way out on a limb (& K.I.S.S.) & WAG that that is it! Holler back. PS dist/cap/rotor all look good? plugs/plug wires OK? EDIT With more thought I had the exact same prob in '85 & it was the Sears white replacement HEI module (4 in a row!) and recently my coil did somewhat the same thing (but didn't you say you replaced the coil?)
Re: 1970 a100 running great then bad then back again, now meltedwires [Re: maxi333] #2020394
02/26/16 07:29 PM
02/26/16 07:29 PM
kauai
maxi333 Offline OP
maxi333  Offline OP
kauai
Yeah im totally confused too... I figured hopefully it was some short and since the wires to the ammeter fried quite a few other wires I decided to start with the whole wiring harness. Luckily someone an hour away had a 69 camper harness for 150 so I'm putting that in and doing the bypass. but I'm running into a few hang ups.
A couple wires are different and was wondering if anyone knew what they might go to... here's an image and there are also a couple wire plugs for the brakes that are not on my 70 tradesman and a 2 wire black with white stripes plug under the floor mat near the brake pedal that the 69 harness has no plug for.
Any help would be great as I'm broke and stuck at a friend's out of town in a crazy town called apache junction... it's a little crazy in this town
Re: 1970 a100 running great then bad then back again, now meltedwires [Re: maxi333] #2020399
02/26/16 07:33 PM
02/26/16 07:33 PM
kauai
maxi333 Offline OP
maxi333  Offline OP
kauai
Shoot I can't attach the photo but in the dash I have an extra light blue wire with an eye end, a pink with black stripe with post plug, darker blue female spade and the only thing extra from my original 70 dash is the orange post for the temp Guage and the white post for the oil pressure Guage. .. thanks yall, I'll try to post the pic later.
Re: 1970 a100 running great then bad then back again, now meltedwires [Re: maxi333] #2020515
02/27/16 12:16 AM
02/27/16 12:16 AM
the wiring diagrams at www.mymopar.com might help. I've heard they are missing a circuit here and there but I've had excellent luck with their schematics. where exactly is the harness/loom/wire ends at in question?
Re: 1970 a100 running great then bad then back again, now meltedwires [Re: maxi333] #2020554
02/27/16 01:46 AM
02/27/16 01:46 AM
kauai
maxi333 Offline OP
maxi333  Offline OP
kauai
Most of them are behind the dash at the moment, except the brake wires im still trying to figure out... I found the pink wire attaches to the temp and the dark blue attaches to the emergency flashers but the rest of the flasher wire connectors are missing too, still not sure on the light blue wire with the eye connector at the end?
Re: 1970 a100 running great then bad then back again, now meltedwires [Re: maxi333] #2020555
02/27/16 01:47 AM
02/27/16 01:47 AM
kauai
maxi333 Offline OP
maxi333  Offline OP
kauai
Thanks for the link but couldn't find the a100 or a diagram with the wires I have from this camper harness. .
Re: 1970 a100 running great then bad then back again, now meltedwires [Re: maxi333] #2020583
02/27/16 03:02 AM
02/27/16 03:02 AM
You might grab your VOM & start ohming em & see what wires on the other ends are hot. Need jumper wires with alligator clips (I make up several long ones for general work & they would work fine for this) & I always pull a batt cable before I switch the meter to ohms so the only power is coming from the meter battery.
Re: 1970 a100 running great then bad then back again, now meltedwires [Re: RapidRobert] #2020702
02/27/16 01:08 PM
02/27/16 01:08 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
That's really the only way to know unless it's spotted visually. The battery has to be disconnected before ohm checking power wires to ground.
Re: 1970 a100 running great then bad then back again, now meltedwires [Re: maxi333] #2020839
02/27/16 05:44 PM
02/27/16 05:44 PM
kauai
maxi333 Offline OP
maxi333  Offline OP
kauai
shoot don't think i have access to a meter, broke down out of town and flat broke myself. i'm at a friends so i'll see if he has one.
finally can post some pics... i've since connected the pink to the orange post for the temp, i believe the white wire is for my oil pressure gauge while the replacement harness has just an oil light white and black wires, i think the extra red and white wires down near the brake proportion valve go to the brake light switch under the pedal(must have been in a different location for the camper?
i have no idea where the light blue wire with eye goes behind the dash, no clue where the wires for the flashers are lol??? also there is one less field wire going toward the ballast, will that matter with my dual field alternator?
thanks so much smile
Re: 1970 a100 running great then bad then back again, now meltedwires [Re: maxi333] #2021480
02/28/16 08:24 PM
02/28/16 08:24 PM
kauai
maxi333 Offline OP
maxi333  Offline OP
kauai
Ok finally got most of the wires all wired up started the van up and it ran smooth for a couple minutes then back to running rough again. .. seemed like it is missing? Then when I Rev it up runs worse and starts to want to backfire?? I'm going to swap my new coil but I don't know what else to check? ?
Re: 1970 a100 running great then bad then back again, now meltedwires [Re: maxi333] #2022386
03/01/16 03:05 AM
03/01/16 03:05 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Is this motor the original to the A 100? Has it ever had a timing chain installed? Do you have access to a timing light? And, is the timing steady or fluctuating? When its running like crap, shut it off, bring #1 up on compression, pull off the dist cap and see if the rotor is pointing towards #1 plug wire. Also, with the cap off, turn the motor backwards by hand and check to see if the motor will turn a ways before the rotor moves. There should be very little delay when you change the direction the motor was turning before the rotor moves. a delay indicates slop in the timing chain & gears.
Have you cleaned both ends of the negative cable or replaced it? Do you have a good clean block surface the neg cable connects to?
When the motor is running poorly, is there gas in the carb? I've seen a lot of old gas tanks with stuff floating around in them that would float to the fuel pickup and plug it up completely or near completely and cause a poor running condition after a drive. Might also b worth taking the gas cap off and see how it runs, a plugged gas tank vent will mess you up too. Gene
Re: 1970 a100 running great then bad then back again, now meltedwires [Re: poorboy] #2022398
03/01/16 03:25 AM
03/01/16 03:25 AM
I'm wondering if it has a vac leak that is showing up when it warms up cuz it is leaner then & until then the rich mixture from the choke covers that up.
Re: 1970 a100 running great then bad then back again, now meltedwires [Re: maxi333] #2022576
03/01/16 01:58 PM
03/01/16 01:58 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
You say the points need constant adjustment.
Maybe they are burning, instead of wearing out of adjustment.
Did you lubricate them?
Been awhile, but I seem to remember that will happen if the coil is wired backwards.
Would go along with the wiring trouble.
Good luck,
that will be a fun truck once you get it sorted.
I have mechanical Aptitude.
I can screw up anything.
