Plating help #201599
01/22/09 10:53 PM
01/22/09 10:53 PM
N
NITROUSN Offline OP
NITROUSN  Offline OP
N
Need to identify what correct plating process should be done on the following items on my 69 charger project.
1- hood latch, actuator pivot lever, control rod.
2- secondary hood latch
3- trunk latch
4- door latches, strikers, shims, and screws.
Is there any other items I should consider?
Re: Plating help [Re: NITROUSN] #201600
01/23/09 12:09 AM
01/23/09 12:09 AM
Massachusetts
LYNCHROAD69.5 Offline
Massachusetts
Don't know if this will help...Plating guide written by Frank Badalson. Muscle Car Review, September 2001 issue.
Re: Plating help [Re: LYNCHROAD69.5] #201601
01/23/09 12:10 AM
01/23/09 12:10 AM
Massachusetts
Massachusetts
pg 2
Re: Plating help [Re: LYNCHROAD69.5] #201602
01/23/09 12:11 AM
01/23/09 12:11 AM
Massachusetts
Massachusetts
Pg 3
Re: Plating help [Re: LYNCHROAD69.5] #201603
01/23/09 02:08 PM
01/23/09 02:08 PM
N
NITROUSN Offline OP
NITROUSN  Offline OP
N
Thanks Wayne. Now I just need to figure out exactly what process was used on each part.
Re: Plating help [Re: NITROUSN] #201604
01/24/09 12:18 AM
01/24/09 12:18 AM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
Kool. Hope this gets put in the archives.
Re: Plating help [Re: moparmojo] #201605
01/24/09 03:14 PM
01/24/09 03:14 PM
Northern N.J.
hemi_doug Offline
hemi_doug  Offline
Northern N.J.
next question...who does that type of plating? I have a bunch of stuff I need to get plated as well....
71 440-6 4spd & 69 Hemi 4spd
