New PS pump? #2013545
02/16/16 11:40 PM
02/16/16 11:40 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
I was wondering if anyone has any experience with this company?
http://www.streetlegaltv.com/features/as...y-with-turn-one
I was thinking that it might be good for a Borgenson box and the serpentine belt kit for my 572 hemi....tim
http://www.turnone-steering.com/#!online-store/ciui/!/Universal-Mount-Pump-w-Reservoir/p/47851761/category=12405744
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: New PS pump? [Re: astjp2] #2013581
02/17/16 12:19 AM
02/17/16 12:19 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
its just a zf power steering pump. most newer us cars and some imports use them. that adjustable flow valve is kinda neat, hadn't seen that yet. that pump will fit with our serpentine belt kit but you will need a remote mount reservoir
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: New PS pump? [Re: Jerry] #2013702
02/17/16 02:06 AM
02/17/16 02:06 AM
Victoria B. C Canada
gold66cuda Online content
gold66cuda  Online Content
I run basically the same set up, I have a Tuff Stuff steering pump, installed the Borgensen shim kit in it and run the Turn One adjustable flow control valve. I run the new Borgensen steering box as well, I use a V grove pulley on my small block set up and made my own brackets. So far this set up works really good.
Re: New PS pump? [Re: astjp2] #2013767
02/17/16 06:45 AM
02/17/16 06:45 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Do you notice any difference when dialing it up and down? Do you know what pressure you are running on that box? Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: New PS pump? [Re: astjp2] #2014048
02/17/16 04:41 PM
02/17/16 04:41 PM
I'm not totally sure of the pressure as I have never had a gauge on it but I did install the 5 shims from the Borgsen Shim kit and if I recall that would take the pump to about 850 PSI. I can feel a difference when I adjust the flow regulator, I run between setting 4 and 1 depending on what I am doing with the car. The car is not heavy right at 3200LBS, it gives a comfortable feedback at speed with it on the lowest setting and I have no hard steering issues at parking speeds.
