Cable question for pushbutton trans racers.. #201307
01/22/09 07:46 PM
01/22/09 07:46 PM
NJ-USA
HPMike Offline OP
HPMike  Offline OP
NJ-USA
Has anyone used the Imperial conversion on a late trans in their early car?? Is this setup just a "street" deal, or would/could it be trusted to precisely shift a manually shifted drag race only car?? I have some doubts, but would like some input if anyone has any to offer.
MB
Re: Cable question for pushbutton trans racers.. [Re: HPMike] #201308
01/22/09 08:12 PM
01/22/09 08:12 PM
Bowler Wisconsin
Smoparmike Offline
Smoparmike  Offline
Bowler Wisconsin
I was wondering the same thing. Someone must be using this setup?
Re: Cable question for pushbutton trans racers.. [Re: HPMike] #201309
01/22/09 10:15 PM
01/22/09 10:15 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
I am going to use a late-model trans with the OEM pushbuttons ... but I will not have park.
NO NEED to spend those huge dollars on that conversions(is it near 200$ now?) .... just adapt the cable to the standard shift-lever ... but use the softer spring in the VB.
Re: Cable question for pushbutton trans racers.. [Re: HPMike] #201310
01/22/09 11:32 PM
01/22/09 11:32 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
What's wrong with the great original design??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Cable question for pushbutton trans racers.. [Re: hemi-itis] #201311
01/22/09 11:36 PM
01/22/09 11:36 PM
Having to find an original '65 model trans.........
That cable is designed to work with the pushbutton shifter and the later model trannys........
Hey Mike, I haven't used that particular cable, but I have used one of their sets of "original replacement" cables and, honestly, I wasn't impressed..........I'd get the shifter adjusted and it wouldn't repeat......Apparantly, the outer sleeve was compressing and stretching??? That may be fixed now, since that was one of the earlier sets they'd made.......
Re: Cable question for pushbutton trans racers.. [Re: hemi-itis] #201312
01/22/09 11:37 PM
01/22/09 11:37 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
I agree with hemi-itis, use the old stuff, I still have my buttons in the stock location, but can't help you really, have no experience with the new tranny old shift.
Re: Cable question for pushbutton trans racers.. [Re: hemi-itis] #201313
01/22/09 11:39 PM
01/22/09 11:39 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
LOL ... but for the PB shifter to be "right" .... gotsta'be on the LEFT !
Re: Cable question for pushbutton trans racers.. [Re: dOoC] #201314
01/23/09 02:24 AM
01/23/09 02:24 AM
NJ-USA
HPMike Offline OP
HPMike  Offline OP
NJ-USA
Thanks for the replies....
I have no problem with the early stock design, however I have had experiences where a foulup in the mechanism has burnt up a unit.
The dilemma I have now is this. I am building a maxie car for a customer and I already have a fully done late trans that is ready to go. As Wayne stated, if I wanted to go back to the stock setup I will need to find a 65 BB unit, and start the build from there. This is a car designed for FAST, so quite a bit of work is involved to get the trans "just right". It would just be easy to use this "dialed in" later trans than to start from scratch. Not to mention the cost savings involved with not having to get another tranny and set it all up.
If anyone has any real world experiences, I am all ears.
MB
Re: Cable question for pushbutton trans racers.. [Re: HPMike] #201315
01/23/09 03:59 PM
01/23/09 03:59 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I run the 65 trans in my car. The rotating assy in the trans can be swapped from a late model except for the output shaft,case,and tail housing. I talked to the owner of Imperial (he's not far from me). The only concern he has is the releasing from park. He says his set-up could be damaged pulling the lever out of park on an incline. As far as shifting he had no issues. The push button valve body detent spring on the rooster combo is much weaker than a late model. I don't remeber if their set-up changes that or not. As far as the 65 set-up. I've run thousands of passes with no issues. The shift mechanism is very simple. Cables in good condition and proper adjustment is all that is required. I may see them at the Chrysler swap meet this weekend,they're usaully there. If you have any questions PM me before Sunday.
Doug
Re: Cable question for pushbutton trans racers.. [Re: dOoC] #201316
01/24/09 08:45 PM
01/24/09 08:45 PM
hemi-itis Offline
hemi-itis  Offline
Not always,just take a great idea and make it better.I saw this set up and spent an hour just Gotta love it!!
Re: Cable question for pushbutton trans racers.. [Re: hemi-itis] #201317
01/24/09 09:16 PM
01/24/09 09:16 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
whateverfloatsyerrboat h i !! ... I see you have seen that Art Carr gooseneck shifter.
And your R button "protecter" is
but what is that green lite for?
Re: Cable question for pushbutton trans racers.. [Re: dOoC] #201318
01/24/09 10:58 PM
01/24/09 10:58 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Hey Mike is that 63 Dodge pic you posted Dave Finn's car ??
You could always do what I did for now as I used a 1970 trans that I had and did a stock type rebuild on it. I dont run no class so I just added a floor shifter for now as my funds were limited. I have the push buttons and all the linkage still in the car and hope to hook them back up when I can get what I need to make the push button's work with the newer trans. Ron
Re: Cable question for pushbutton trans racers.. [Re: 383man] #201319
01/24/09 11:11 PM
01/24/09 11:11 PM
NJ-USA
HPMike Offline OP
HPMike  Offline OP
NJ-USA
Ron:
Yes, that is Finn's FAST car that I built last year. Well, seems as though someone else is thinking that the MW isn't so bad after all. So the "new" MW project is just about to get started. The floor shifter is a neat idea, but won't fly for FAST. I guess the search is on for a 65 unit, that is unless someone can give me some real world feedback on this early/late deal.
MB
Re: Cable question for pushbutton trans racers.. [Re: HPMike] #201320
01/24/09 11:18 PM
01/24/09 11:18 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Dave Finn's car is really a nice 63 Maxie car. I heard his eng dyno'd at close to 700hp ???? I know he had run 11.04 and was knocking on the 10's. I wish I had the coin to build my 63 for FAST but since I dont it was not a problem for me to use floor shifter for now. It can always come out later. I always felt the Max Wedge would make a good FAST car and it looks like you guys proved that. Ron
Re: Cable question for pushbutton trans racers.. [Re: 383man] #201321
01/24/09 11:29 PM
01/24/09 11:29 PM
wisconsin
jp66charger Offline
jp66charger  Offline
wisconsin
Don't mean to high jack, but I'm right in the middle of working on a '63 polara and my next project is the tranny. Planned on just putting a late model tail shaft on a early tranny for driveshaft reasons, but that may not be possible??? Any body have a phone number for Imperial and maybe a contact name? Thanks for any info. JP
Re: Cable question for pushbutton trans racers.. [Re: dOoC] #201322
01/25/09 12:22 AM
01/25/09 12:22 AM
hemi-itis Offline
hemi-itis  Offline
Are you sure that's an Art CArr unit??I was told it was fabbed by a creative individual I'm not sure what the the toggle switch or the green light are for.The owner of the car said the shifter was in there when he bought it.
Re: Cable question for pushbutton trans racers.. [Re: hemi-itis] #201323
01/25/09 12:32 AM
01/25/09 12:32 AM
California, USA
P
Phil Saran Offline
Phil Saran  Offline
P
California, USA
It's very similar to what Art Carr used to sell
(don't know if they still do?).
A buddy had one of the Art Carr units (chome)
in his 65 Belveder I with a Hemi. But this was
back before 1970.
Phil Saran Parker, Colorado
Re: Cable question for pushbutton trans racers.. [Re: hemi-itis] #201324
01/25/09 12:36 AM
01/25/09 12:36 AM
hemi-itis Offline
hemi-itis  Offline
I will make my junk look sanitary one of these days
Re: Cable question for pushbutton trans racers.. [Re: hemi-itis] #201325
01/25/09 08:32 AM
01/25/09 08:32 AM
your junk looked pretty good to me!!
but whats the green light for?
Re: Cable question for pushbutton trans racers.. [Re: HPMike] #201326
01/25/09 02:25 PM
01/25/09 02:25 PM
OH
junkyardmaxie Offline
OH
hi, i always use the org 63-64 push putton trunion trans ,and put the 65 slip yoke tail shaft on.put the turbo action valve body in, with hp rebuid, it works fine.use all orig cables etc.the 65 big block trans are going for as much as 450. for core i have 2- 65 tail housing, and shafts cleaned,painted , new seal installed, ready to bolt on for $200.00 plus shipping. just a thought ? will be at the all mopar sled city swap meet at hillard ohio next sat 1/31 franklin county fair grounds thanks
