99 Cherokee 4.0 A/C yes Heat No #2010082
02/11/16 08:34 PM
02/11/16 08:34 PM
Eastern,NC
68GTS383 Offline OP
68GTS383  Offline OP
Eastern,NC
My Jeep only has about 120K miles and the heat no longer works at all. Any input? A friend told me that the Jeeps have trouble with a Blend Door.Any one had this problem? If it is the Blend Door,where is it located and how hard is it to replace? Thanks!
Re: 99 Cherokee 4.0 A/C yes Heat No [Re: 68GTS383] #2010091
02/11/16 08:39 PM
02/11/16 08:39 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Have you checked to see if is a blocked heater core? Are the heater hose temps hot in and warm out?
Re: 99 Cherokee 4.0 A/C yes Heat No [Re: stumpy] #2010161
02/11/16 10:22 PM
02/11/16 10:22 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
Air in the system. .my ram was bad for that air bubbles in water system no heat ..
Re: 99 Cherokee 4.0 A/C yes Heat No [Re: 68GTS383] #2010999
02/13/16 11:02 AM
02/13/16 11:02 AM
southeast, mich
MachoMan Offline
MachoMan  Offline
southeast, mich
Had 3 Cherokees and never a problem with blend door.
ALL were coolant/coolant delivery issues when no heat. They were 97, 98 and 99's.
They are WELL known for coolant issues esp 4.0's.
Please register your Dodge truck here 1972-1980 Dodge truck registry
Re: 99 Cherokee 4.0 A/C yes Heat No [Re: MachoMan] #2011125
02/13/16 03:43 PM
02/13/16 03:43 PM
wooster ohio
3
3csalvage Offline
3csalvage  Offline
wooster ohio
remove or cut the hoses to splice them, flush backwards with water coolant out of the heater core,blow out as well I don't use compressor(too much pressure) then fill with white vinegar let set 10 minutes or so flush and refill! Low cost works most of the time!
Re: 99 Cherokee 4.0 A/C yes Heat No [Re: 3csalvage] #2012944
02/16/16 02:34 AM
02/16/16 02:34 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Do you hear any strange noises when switching from hot to cold and back? Is it a dual system? plastic shafts on Blend air doors break. there is a kit to fix them from Jeep, do them a lot.
Just noticed is this a Cherokee or Grand Cherokee? If it's a Cherokee yes look for a clogged core!
Re: 99 Cherokee 4.0 A/C yes Heat No [Re: 3csalvage] #2013006
02/16/16 09:24 AM
02/16/16 09:24 AM
Mo.
racerx Offline
racerx  Offline
Mo.
I just back flush mine with air, but I turn the pressure down to bout 25 psi and did quick burst. wave
