stock K frame and rack and pinion steering
#2012685
02/15/16 07:34 PM
02/15/16 07:34 PM
dartman366
Mt. Vernon, Ohio
anyone made this conversion from the conventional steering box over to the rack system? what all is involved to do this and any pics would be great, not interested in a complete tubular K frame as every thing I have has been updated with tubular upper and lower control arms, aluminum radius rod's and have removed the torsion bars and installed coilover's so I have no need to replace all that, just want to install RP steering.
Re: stock K frame and rack and pinion steering
[Re: dartman366]
#2012709
02/15/16 08:13 PM
02/15/16 08:13 PM
Posts: 9,047 fredericksburg,va
cudaman1969
Itch Nutz
Itch Nutz
fredericksburg,va
We did a 68 dart back in the day, used the later k-frame where sway bar went through the k. Used a pinto rack. Got it as close to being straight with the arms to each spindle. The more angle there is the more problems with turning and backing. If you look at the stock pinto-mustang II, the rack is behind the spindle ends(tie-rod). I switched the lower BJ from side to side, might have done the upper also, been awile. Never had any adverse affect on the car backing or turning, car went 131 mph, straight, keep all the other stock stuff just looking for oil pan clearance, since engine was set way back. Saw a few cars with turning problems and wondered what they did wrong. They had the rack way out front and arms at a 22-30 degree angle back, tie rod will go past center and wheel goes to frame. Then the wheel has to be pulled back by hand. This changeover is not perfect but will work. I spent a lot of time doing my tube chassis car making the rack shorter, setting in the right place so I had no bump steer or ackerman problems. One other thing, the swivel joint on the rack has to line up with the lower CA pivot for both sides or you get bump steer problems. Good luck.
[Re: Monte_Smith]
#2012756
02/15/16 09:37 PM
02/15/16 09:37 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Swap the lower BJ side for side.......mount the rack inside the k-member, keeping it all in a straight line and the proper length rack, it will all work just fine Seen this done. Had to grab the wheel and help pop it out of bind when it was over steered backing up. Guy went and had arms bent out to correct. He later bought a k-member
[Re: dartman366]
#2012766
02/15/16 09:44 PM
02/15/16 09:44 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
When I originally set up a Pinto rack and swapped balljoints, I had 1/4" thick washers added to one side of the balljoint mounting holes, then flat milled across both mounting holes. Keeps the tie rod end straight, doesn't bind backing up any more.
[image][/image]
[Re: Monte_Smith]
#2012783
02/15/16 10:02 PM
02/15/16 10:02 PM
Posts: 5,238 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Isn't it crucial to get the rack pivot points to align with the lower control arm pivot points? Or at least close... I seen one done a few years ago that bent the rack when he hit a bump... That car also had terrible bump steer... ![work work](/ubbthreads/images/graemlins/custom/work.gif)
...FAFO...
[Re: Monte_Smith]
#2012811
02/15/16 10:28 PM
02/15/16 10:28 PM
dartman366
Mt. Vernon, Ohio
Thank's guys,I thought I had seen it done before on some cars somewhere, pic's if possible would help me out the most, once I see it then I have a better idea in my mind what to do and what I need to watch for, I have no problem getting thing's fabbed up just need to make sure it's all in the right place. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: Darryls-Demon]
#2012827
02/15/16 10:45 PM
02/15/16 10:45 PM
Posts: 2,155 Tucson, Arizona
clonestocker
Tucson, Arizona
I to would like to go this route for my next street-strip car, that way I would not need to cut up my oil pan to clear an after market cross member. You don't have to modify the oil pan with a small block.
[img] [/img]
[Re: dartman366]
#2012893
02/16/16 12:27 AM
02/16/16 12:27 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Here is some pics of my old Challenger racecar with the rack in the middle of the stock k. Was great in a straight line, no bump steer at all. Ackerman though, this thing would go through a set of front tires every other season. Perfect for a drag car because it wanted to go straight, couldn't oversteer the thing if you tried!
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
