Duster Progress..........pics inside.
#2012875
02/16/16 12:53 AM
02/16/16 12:53 AM
Posts: 12,404 Taxes & Virus's R-US, NY
Dragula
Well, as bracket racers do, we need to fix our junk after putting a bunch of laps on it...... And I had a flex plate come loose off the crank that pushed it into the thrust bearing....Damage wasn't too bad, but ened my cars season two races early. So I had to borrow a Hemi car for the last two races and enjoy the season doing wheelies... Its amazing how many parts actually have to be replaced every season....A HUGE thanks to Farley's Racing Engines!!!!! -Spray welded the crank & re-cut it Three rocker arms -All the bearings -New rocker shafts -New rings -New valves -Fixed the oil pan -Ported the intake -Ported the intake ports on the heads -Re-cut the valve seats -Re-cut the new valves to match -Re-re-welded the headers -New damper -New lower crank pulley -New Flex plate & bolts -Even the alternator pulley spacer was toast
Re: Duster Progress..........pics inside.
[Re: Dragula]
#2012945
02/16/16 02:35 AM
02/16/16 02:35 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
You wouldnt be able to see the sticker on the flex plate if you put it engine side.
Motor looks nice
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Dragula]
#2013081
02/16/16 01:12 PM
02/16/16 01:12 PM
Posts: 12,589 Great Neck,LI,new york
hemi-itis
We do what we have to do! Yes I have towed during blizzards!! I also see Super Performance valve cover gaskets,,,,
[Re: roadhazard]
#2013125
02/16/16 02:23 PM
02/16/16 02:23 PM
Thumperdart
State of confusion
Looks fantastic! Hope you have some good luck with it this season. Thanks for using the "good stuff" Thumper you are weak! No, SMART........I`ve lived in Chicago but nuuttin gets colder than Germany which I also lived in so WEAK no, SMART YES.............
