Re: 1988 Dodge D250 Project
[Re: 70AARcuda]
#2007578
02/07/16 09:23 PM
02/07/16 09:23 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Fired the old Dodge up this afternoon...let it run for a few seconds...got a fuel leak...old holley carb....open headers..
had no water cause i need 3 feet of heater hose....but everything is basically working..
no computer at all..
checked the FSM and found how to adjust PS belt....
few more thing and she is rolling again...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#2009661
02/11/16 01:49 AM
02/11/16 01:49 AM
70AARcuda
las vegas
Got heater control valve replaced..new heater hose too..
Put a holley regulator on it...and adjusted the fuel pressure down to 5 psi..
put water in it...and found it spraying water between the water pump and timing change cover...dam..
fire it up..and let it run ...beside the water leak...got a few thing to fix but nothing major...Old truck should be back in service in a couple of weeks...gotta work on a Duster for next weekends race..
But very happy I was able to get rid of throttle body and computer..
Tony
[Re: 70AARcuda]
#2012762
02/15/16 10:42 PM
02/15/16 10:42 PM
70AARcuda
las vegas
Had some free time to work on D250 today...got the water leak fixed...
Then I noticed that the timing mark was nowhere close on the damper and timing chain cover...turned engine over by hand this morning and yes...the damper had slipped....Removed and replaced it this morning......
Need to get eddy 1407 installed...got the thin adapter plate i needed to fix on the eddy performer intake...
and need to swap out headers...got a beautiful set of ceramic coated headers for the truck in a package deal early this year...then off to the muffler shop.
Tony
[Re: 70AARcuda]
#2013678
02/17/16 01:41 AM
02/17/16 01:41 AM
70AARcuda
las vegas
Got the eddy carb fixed ..i think..
moved the distributor where i thought it should be now that the damper is showing the correct timing...fired right up...
set the timing at 12 degrees initial for now...
Seems to have a small vacuum leak as turning the idle screws in all the way it still will run...slows down but still runs...and smells a little rich...I put the eddy adapter on..then put an 1/2 spacer on...maybe I need to rethink that 1/2 spacer...
But everything is going good...no water leaks..no oil leaks..still gotta hook up the gas pedal..
Tony
[Re: 70AARcuda]
#2014428
02/18/16 02:06 AM
02/18/16 02:06 AM
70AARcuda
las vegas
Changed out the carb..i have a pretty new holley 2300 350 cfm carb...
318 is purry like a kitten...timing dialed in......need to get gas pedal hooked up...lol
Tony
[Re: 70AARcuda]
#2015560
02/19/16 05:36 PM
02/19/16 05:36 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I have a E-Brock Performer #2176 manifold and #1406 Carb on my '87 318 and I wish I had bought the smaller (500 CFM) #1403 because I had to buy the #1487 tuning kit to get the tune close. I had a #1407 on my '64 Polara with a 440 cruiser and it was not a happy combination, terrible throttle response with 727 and tight converter. JMHO. http://www.summitracing.com/parts/edl-1403/overview/
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: 70AARcuda]
#2015815
02/20/16 01:18 AM
02/20/16 01:18 AM
70AARcuda
las vegas
I probably had a vacume leak between the adapter and spacer...did not want to deal with it...
I have owned that 1406 since brand new back in 2002...
waiting on the lokar universal bracket and cable to get the gas pedal hooked up
Tony
[Re: 70AARcuda]
#2020165
02/26/16 01:41 PM
02/26/16 01:41 PM
70AARcuda
las vegas
got the lokar cable bracket and throttle cable installed just need to cut cable to length. Just got the header reducers with bungs on them from Jegs. I want to swap out headers,, got a brand new set of ceramic coated headers in a package deal, now I get to get the old cruddy ones off.
Biggest problem I got is getting time to work on this thing...so close..
Tony
[Re: 70AARcuda]
#2020975
02/27/16 10:35 PM
02/27/16 10:35 PM
70AARcuda
las vegas
Finally made a throttle cable that would fit and work...went back to the Eddy 600 carb...I thought it had a vacuum leak...and would not idle down...it was on the fast idle cam...LOL
use the old cable from the TBI and cut it to length..use the cable from the chinese lokar cable and a stock bracket...
removed and replaced passenger side header...new ceramic ones..need to driver side in morning..it is a PIA since it hits the frame...
drove it around the block with open headers...1st time in over an year...October 2014 I started..
need to upgrade the stereo too...
Tony
[Re: 70AARcuda]
#2021846
02/29/16 01:37 PM
02/29/16 01:37 PM
70AARcuda
las vegas
Had to flatten no. 1 tube on driver side to get it to fit...but the ceramic headers are on...got the reducer bolt on with bung for wideband.
Muffler shop near house was closed on Sunday...probably wont get it done this week as I am heading out of town on Friday and in training class rest of week....
got to make a list of small things to do...stereo..seat covers even through the bench seat is in great condition...and new tires..
I wonder if I can find a new back window that opens...
Tony
[Re: 70AARcuda]
#2042414
03/31/16 12:40 AM
03/31/16 12:40 AM
70AARcuda
las vegas
new saddle blanket seat covers on it...new dash cover...
muffler shop said they would have to install catalyst converters on the truck since it was an 88 on they would get in trouble with the DVM, the truck is registered as a classic vehicle and no smog is required...I said NOPE...I will do it myself...
Hooker makes a dual exhaust kit...bought it and two turbo mufflers...just got done tonight..a few hours for two night after work...instead of clamps..mig welded the fitting...no leaks..
so now the truck is good to get back on the highway...needs some tires in a few weeks...but around town should be ok..
will get a picture tomorrow...needs to hose down engine bay...dust has been blowing all over in vegas the past few days..
got a new stereo for it also...
Tony
[Re: 70AARcuda]
#2043264
04/01/16 01:36 AM
04/01/16 01:36 AM
70AARcuda
las vegas
couple of pictures of engine went I started..
Tony
[Re: 70AARcuda]
#2043267
04/01/16 01:38 AM
04/01/16 01:38 AM
70AARcuda
las vegas
Just took these this afternoon...
Tony
[Re: 70AARcuda]
#2043683
04/01/16 05:32 PM
04/01/16 05:32 PM
Polarapete
Graham, WA
Just took these this afternoon... That looks very familiar just like my '87 and I see you lost your air pump, too. Like the headers, but they are not on my list yet.
[Re: 70AARcuda]
#2043687
04/01/16 05:34 PM
04/01/16 05:34 PM
70AARcuda
las vegas
Those headers came in a package deal...but I had a set of the cheap old headers available also...
Tony
