headers for blown 340 #201240
01/22/09 05:37 PM
01/22/09 05:37 PM
sweden
1Fast340 Offline OP
1Fast340  Offline OP
sweden
planing the rebuild of my 340 alitle short on money so i will try to get by as cheap as possible with what i do
spec 340 with 8-8.5:1compresion have not ordered any pistons yet
lysholm screw supercharger should be able to move enough air for over 700hp
cam will probably be my old compcams XE solidroller 242/248@.050 and .570/.576 lift probably not the best bet for a cam but i may not have enough money to get a new one unless it will be a real bad choice for cam ?
heads are fully ported eddy heads
carb will probably be some kind of dominator since the blower has a single dominator carbflange.
what size and lenght headers would be recomended for this aplication?
not afraid of building my own, i have some TTI stepheaders now and i gues they are alitle small and i know they dont match the exhaustport very good as is..
i also have a hookerflange kit with short pipes on they are 1 3/4" may be enough?
any more sugestions?
Re: headers for blown 340 [Re: 1Fast340] #201241
01/22/09 06:13 PM
01/22/09 06:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Blower motors dont need a collector, they dont need
to draft in a charge. I would look at a 1 7/8" min
to 2" tube. If your going to run it with a collector
look at a 3 1/2". Length wont matter either on the
primaries.... make or buy something that fits
Re: headers for blown 340 [Re: MR_P_BODY] #201242
01/23/09 02:51 AM
01/23/09 02:51 AM
sweden
1Fast340 Offline OP
1Fast340  Offline OP
sweden
thanks
not neading to care to much about lenghts sure is a big advantage when trying to pack 1 7/8"- 2"primarys in a small abody, there will be collectors since this thing will be streetdriven some atleast to the track and home again
Re: headers for blown 340 [Re: 1Fast340] #201243
01/23/09 03:45 PM
01/23/09 03:45 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
My blown 340 runs similar cam specs on 112 LCA(solid not a roller),home ported iron heads,7.5-1,2 750 Carters,2" headers,3"exh. 12PSI with a old worn GMC 6V-71 blower mounted on a prehestoric Wiend single 4 barrel manifold. 4.30 gear,loose converter,slicks 11.05@124 thru mufflers @ 3850 lbs. With a 9" converter and BFG drag radials 11.17@121. I honestly don't think you'll give up a ton with smaller headers. Years ago I ran a milder combo. 214@.050 /467" lift cam, 1 5/8" headers, 3.91 gear,stock 340 coverter, same wieght. It went 11.88@113.
Doug
Re: headers for blown 340 [Re: dvw] #201244
01/26/09 01:11 PM
01/26/09 01:11 PM
sweden
1Fast340 Offline OP
1Fast340  Offline OP
sweden
My blown 340 runs similar cam specs on 112 LCA(solid not a roller),home ported iron heads,7.5-1,2 750 Carters,2" headers,3"exh. 12PSI with a old worn GMC 6V-71 blower mounted on a prehestoric Wiend single 4 barrel manifold. 4.30 gear,loose converter,slicks [Email]11.05@124[/Email] thru mufflers @ 3850 lbs. With a 9" converter and BFG drag radials [Email]11.17@121.[/Email] I honestly don't think you'll give up a ton with smaller headers. Years ago I ran a milder combo. [Email]214@.050[/Email] /467" lift cam, 1 5/8" headers, 3.91 gear,stock 340 coverter, same wieght. It went [Email]11.88@113.[/Email]
Doug
what kind of car was it thinking if you may have any pics of those big headers,just interesting seing how others have solved the problem with spacelimitations?
i have not seen alot of pics at all of bigtube headers for abodys at all actualy..
i kind of like the challange alitle also doing something like this
i know tigwelding will be best but will it be ok to just migweld since it would save alot of hours of work?
Re: headers for blown 340 [Re: 1Fast340] #201245
01/26/09 01:15 PM
01/26/09 01:15 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
DVW's car is a '76 Volare. It has A-body headers on it though. One tube passes through the inner fenderwell...
I think they are Headmans if I remember correctly.
Re: headers for blown 340 [Re: dizuster] #201246
01/27/09 01:05 PM
01/27/09 01:05 PM
sweden
1Fast340 Offline OP
1Fast340  Offline OP
sweden
cool thanks:)
will have a look if i can find any good pics somewhere of that kind of headers to get a good ide about what is possible and what isnt, im going at this hoping i can get it done nicely:)
Re: headers for blown 340 [Re: 1Fast340] #201247
01/27/09 02:20 PM
01/27/09 02:20 PM
Nice to see that you went with the lysholm compressor
Hope to see some build pics later on!
Kommer du till Kjula i sommar kanske ?
//Chrippa
Re: headers for blown 340 #201248
01/27/09 05:10 PM
01/27/09 05:10 PM
sweden
1Fast340 Offline OP
1Fast340  Offline OP
sweden
//Chrippa
yepp its a real beuty, the lysholmblower has moved in and lives on my kitchentable (good thing i live alone imagine the look on the face of the girlfriend seing that)
will try to take som pics:) how about your build is it coming along nicely?
of course, i realy need to beat my friends 11.7sec 65 malibu are you coming there also?
/Micke
Re: headers for blown 340 [Re: 1Fast340] #201249
10/09/09 05:24 PM
10/09/09 05:24 PM
sweden
1Fast340 Offline OP
1Fast340  Offline OP
sweden
still have not got around to complete anything, yea i know thats useless but sometimes things get in the way of building a car
any reason not to build a 4 into 2 into 1 header?
just figuring it may be easier to package?
thinking about 1 7/8" into 2 1/4" or 2½" and then 3½" collectors or is it a bad idea?
thanks
Re: headers for blown 340 [Re: 1Fast340] #201250
10/09/09 07:52 PM
10/09/09 07:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
thanks
Sure that'll work.... you just need to get the gasses
out.... quicker the better
Re: headers for blown 340 [Re: 1Fast340] #201251
10/09/09 09:36 PM
10/09/09 09:36 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Pics?
Re: headers for blown 340 [Re: MR_P_BODY] #201252
10/12/09 05:27 PM
10/12/09 05:27 PM
sweden
1Fast340 Offline OP
1Fast340  Offline OP
sweden
thanks
Great! i bet that piece of information just gave me some groundclearance and also alot less headache building headers
Re: headers for blown 340 [Re: ProSport] #201253
10/12/09 05:29 PM
10/12/09 05:29 PM
sweden
1Fast340 Offline OP
1Fast340  Offline OP
sweden
Pics?
GF or blower ?
sure can take a pic or two if i could just figure out where i put the camera last time i had alitle party
