Chinese Roller rockers #2011737
02/14/16 02:39 PM
02/14/16 02:39 PM
New York
JudyLuvsBees Offline OP
New York
O k mopar fans. Out of the Chinese Roller Rockers which is the best? I'm not a racer . I don't have but maybe 450 horse on my 440. I just want better than stock rockers that are adjustable. Can anyone offer some suggestions?
Re: Chinese Roller rockers [Re: JudyLuvsBees] #2011746
02/14/16 02:45 PM
02/14/16 02:45 PM
tboomer Online work
tboomer  Online Work
Don't buy junk. How is that for a suggestion? Check with Mancini,they used to sell a non needle bearing Harland Sharp rocker that is good. Also watch for a good used set of Isky iron ductile rockers. They pop up here from time to time.
Re: Chinese Roller rockers [Re: JudyLuvsBees] #2011754
02/14/16 02:52 PM
02/14/16 02:52 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Chinese rockers better than stock.
Oxymoron there.
Not gonna find Chinese rockers better than stock.
Don't be the exception.
Re: Chinese Roller rockers [Re: JudyLuvsBees] #2011755
02/14/16 02:53 PM
02/14/16 02:53 PM
Lehigh Acres, Florida
rickstershemi Offline
CK out Scorpian in Jegs or Summit....the are made in the USA and IMO the best of the Lower Buck Products.
Rickster
Re: Chinese Roller rockers [Re: rickstershemi] #2011757
02/14/16 02:56 PM
02/14/16 02:56 PM
Minnesota
peabodyracing Offline
Minnesota
Rickster
I agree!!!!
Lead, follow or get the hell out of the way
Re: Chinese Roller rockers [Re: JudyLuvsBees] #2012977
02/16/16 04:30 AM
02/16/16 04:30 AM
france
jose jones Offline
jose jones  Offline
france
Don't do it!! I had a set of Chinese rockers given to me they broke while breaking in the cam, made a mess out of a Indy head. Harland Sharp after that I learned my lesson.
Re: Chinese Roller rockers [Re: JudyLuvsBees] #2013673
02/17/16 01:39 AM
02/17/16 01:39 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I`ve said it before and will likely say it again.
Rocker arms is THE worst possible part to shop for by price.
Re: Chinese Roller rockers [Re: JudyLuvsBees] #2013690
02/17/16 01:48 AM
02/17/16 01:48 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
PRW
Tony
70 AARCuda Vitamin C
Re: Chinese Roller rockers [Re: JudyLuvsBees] #2014007
02/17/16 03:56 PM
02/17/16 03:56 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I realize your asking about big block rocker arms but I noticed new iron adjustable arms at mancini for only $260 when new iron adjustables for the B R/B are over $400. I wonder why the LA arms are so affordable?
http://www.manciniracing.com/maraenadroar.html
Keep old mopars alive.
Re: Chinese Roller rockers [Re: JudyLuvsBees] #2014010
02/17/16 03:57 PM
02/17/16 03:57 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
And I believe these are the Harland Sharpe high quality bushed arms for your engine.
http://www.manciniracing.com/ben15alro.html
Re: Chinese Roller rockers [Re: 2boltmain] #2014017
02/17/16 04:09 PM
02/17/16 04:09 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Only adjustable B/RB rockers I see are aluminum and cost the same as the SB ones.
http://www.manciniracing.com/manciniracing21.html
Re: Chinese Roller rockers [Re: rickstershemi] #2014505
02/18/16 06:23 AM
02/18/16 06:23 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Rickster
After searching online from what I can find Scorpion doesn't make rocker arms for Mopar (other than AMC). shruggy
They don't show Mopar ones on Scorpion's website, or at Summit or Jegs.
Re: Chinese Roller rockers [Re: JudyLuvsBees] #2014508
02/18/16 07:46 AM
02/18/16 07:46 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Why do you want rollers? unless you jhave lift over 550 it will do nothing for you. Over 550 they will help somewhat with less side load scrubbing. They will give you know power gain over a set of good doctile iron adjustables. Have you ever cleaned up an engine that the roller rocker came apart in? Even the spendy ones do.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Chinese Roller rockers [Re: JudyLuvsBees] #2014511
02/18/16 08:17 AM
02/18/16 08:17 AM
P
Porter67 Offline
Porter67  Offline
P
If more people could do there own hands on product testing and research as well as real world testing many myths could be displaced.
You can use import rockers if you do your homework as well as your own testing and QC.
That is apparent since the majority of us use china based cranks, connecting rods, ect... It just blows dont it to have to admit that our china based stroker kits work, but hey its all good because they are finished here...oook.
I use comp rockers alot, HS are not the chit as some make them out to be, they are simply idiot proof for the masses.
Try a jesel system and you will think the HS are in the same junk class as the HS.
Everything has there place and end user level common sense goes along way as well.
Re: Chinese Roller rockers [Re: SNK-EYZ] #2014565
02/18/16 11:35 AM
02/18/16 11:35 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Rickster
They list them on their website but not on Summit or Jegs.
I'm gonna stop by Summit on my way home someday and see if they can explain why that is shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: Chinese Roller rockers [Re: fourgearsavoy] #2014576
02/18/16 11:48 AM
02/18/16 11:48 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I received an email back on 8-10-2015 stating the following from Scorpion about producing rockers for Mopars:
""We are about to release the bb Chrysler rockers but the small block rockers are still in the prototype stage with no honest e.t.a..
Scorpion Racing Products, Inc.""
Re: Chinese Roller rockers [Re: fourgearsavoy] #2014736
02/18/16 04:34 PM
02/18/16 04:34 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Rickster
Gus beer
I had to look again to find the Mopar rockers on Scorpion's website.
They mainly put info about their stud mounted rockers and you have to look close to find the shaft mounted rockers.
Some of their links don't work.
If you click on catalog it's says "server not found".
http://www.scorpionracingproducts.com/endurance-series---shaft-mount.html
http://www.scorpionracingproducts.com/chrysler-shaft.html
