E-body Standard Dash Redline Tachometer ? #2011688
02/14/16 01:21 PM
02/14/16 01:21 PM
Wisconsin
Stewpar Offline OP
Stewpar  Offline OP
Wisconsin
Does anyone have any experience with this tach? How does it perform? Can you see it while driving in the 4th position OK?
Admiration For Multiple Carburetor Vehicles...
Re: E-body Standard Dash Redline Tachometer ? [Re: Stewpar] #2012008
02/14/16 09:48 PM
02/14/16 09:48 PM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
I bought one when they first came out. Which was quite some time ago. I installed mine next to the speedo and moved the other gauges over.
It looks great but for some reason won't go over 2200 rpm. I just haven't got around to figuring out why. Others have used them with no issue.
Re: E-body Standard Dash Redline Tachometer ? [Re: Finoke] #2012087
02/14/16 10:58 PM
02/14/16 10:58 PM
Wisconsin
Stewpar Offline OP
Stewpar  Offline OP
Wisconsin
That's perfect! Did you have to change any wiring by moving everything over?
Re: E-body Standard Dash Redline Tachometer ? [Re: Stewpar] #2012298
02/15/16 10:42 AM
02/15/16 10:42 AM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
I did this about 6 to 8 years ago. I don't remember needing to modify the existing wiring. But I did have to modify the spot to fit the tach. I will try to post some pics...
Re: E-body Standard Dash Redline Tachometer ? [Re: Finoke] #2012299
02/15/16 10:43 AM
02/15/16 10:43 AM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
grin
Re: E-body Standard Dash Redline Tachometer ? [Re: Finoke] #2012300
02/15/16 10:45 AM
02/15/16 10:45 AM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
coffee
Re: E-body Standard Dash Redline Tachometer ? [Re: Finoke] #2012302
02/15/16 10:46 AM
02/15/16 10:46 AM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
wrench
Re: E-body Standard Dash Redline Tachometer ? [Re: Finoke] #2012341
02/15/16 12:03 PM
02/15/16 12:03 PM
Wisconsin
Stewpar Offline OP
Stewpar  Offline OP
Wisconsin
That's perfect, thanks Tom!
Re: E-body Standard Dash Redline Tachometer ? [Re: Stewpar] #2012620
02/15/16 06:33 PM
02/15/16 06:33 PM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
Glad I could help!
