Hole in Carb: Vac leak HELP! What is this? #2011208
02/13/16 05:44 PM
02/13/16 05:44 PM
Slidell, LA
Plum440 Offline OP
Plum440  Offline OP
Slidell, LA
Hey Guys! Found a source of a carb vac leak. What is this hole that is under the elec choke assembly? I put my finger over the hole and you can clearly feel the sucking and the hissing goes away. Is this supposed to be like this? Nothing in the Eddy service manual addresses this hole. Carb is an Edelbrock 750 elec choke.
Thanks!
70 Challenger, 440, 4-speed, pLuM cRaZy
71 VW Super Beetle Convertible, Lemon Yellow
A couple of Jeeps…
Re: Hole in Carb: Vac leak HELP! What is this? [Re: Plum440] #2011217
02/13/16 06:05 PM
02/13/16 06:05 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
I think hole is where you are supposed to hide your weed.
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: Hole in Carb: Vac leak HELP! What is this? [Re: Plum440] #2011219
02/13/16 06:07 PM
02/13/16 06:07 PM
Slidell, LA
Plum440 Offline OP
Plum440  Offline OP
Slidell, LA
It needs to be a lot bigger than this....
A couple of Jeeps…
Re: Hole in Carb: Vac leak HELP! What is this? [Re: Plum440] #2011230
02/13/16 06:25 PM
02/13/16 06:25 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
I thought the stuff the kids have today was much more powerful - so in theory you don't need that 5lb bag anymore??!
55 Plymouth Project
Re: Hole in Carb: Vac leak HELP! What is this? [Re: Plum440] #2011263
02/13/16 06:54 PM
02/13/16 06:54 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I take it the pic is upside down. Does that carb use a choke piston inside the choke housing ? Ron
Re: Hole in Carb: Vac leak HELP! What is this? [Re: Plum440] #2011275
02/13/16 07:22 PM
02/13/16 07:22 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
Doubt this will help - but this is a pic of the E-Brock in my Dart. I have a manual choke - but the holes are drilled for the electric.
This is the newest version of the E-Brock - I think it is a "Thunder Series" or something.....
55 Plymouth Project
Re: Hole in Carb: Vac leak HELP! What is this? [Re: 383man] #2011370
02/13/16 09:40 PM
02/13/16 09:40 PM
Slidell, LA
Plum440 Offline OP
Plum440  Offline OP
Slidell, LA
No, it's correctly oriented. I think the choke mechanism is operated via a coil in the housing. Thanks.
A couple of Jeeps…
Re: Hole in Carb: Vac leak HELP! What is this? [Re: 19swinger70] #2011371
02/13/16 09:41 PM
02/13/16 09:41 PM
Slidell, LA
Plum440 Offline OP
Plum440  Offline OP
Slidell, LA
Thank you.
A couple of Jeeps…
Re: Hole in Carb: Vac leak HELP! What is this? [Re: Plum440] #2011379
02/13/16 09:49 PM
02/13/16 09:49 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Won't the gas run out like that?
[image][/image]
Re: Hole in Carb: Vac leak HELP! What is this? [Re: sgcuda] #2011382
02/13/16 09:55 PM
02/13/16 09:55 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Looks to me like a press-in vacuum nipple is missing. shruggy
Re: Hole in Carb: Vac leak HELP! What is this? [Re: Plum440] #2011398
02/13/16 10:34 PM
02/13/16 10:34 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The Ebrock choke uses a pull off piston, vacuum operated.
http://www.edelbrock.com/automotive/misc/tech-center/install/1000/1478.pdf
Don't be the exception.
Re: Hole in Carb: Vac leak HELP! What is this? [Re: Plum440] #2011403
02/13/16 10:41 PM
02/13/16 10:41 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
I take it the pic is upside down. Ron
LOL...
Re: Hole in Carb: Vac leak HELP! What is this? [Re: Plum440] #2011419
02/13/16 10:58 PM
02/13/16 10:58 PM
Slidell, LA
Plum440 Offline OP
Plum440  Offline OP
Slidell, LA
I found out it's there to help cool the electric choke. It's normal and to not plug it. thumbs
A couple of Jeeps…
Re: Hole in Carb: Vac leak HELP! What is this? [Re: Plum440] #2011538
02/14/16 01:29 AM
02/14/16 01:29 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
The picture is upside down.
Re: Hole in Carb: Vac leak HELP! What is this? [Re: sgcuda] #2011569
02/14/16 02:19 AM
02/14/16 02:19 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I think its a lycoming aircraft engine they have an updraft carb on the bottom of the engine...{sorry could'nt resist}
Re: Hole in Carb: Vac leak HELP! What is this? [Re: Plum440] #2011599
02/14/16 04:21 AM
02/14/16 04:21 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
The pic is upside down. I was not sure but I thought that used the choke piston in that housing (not an external choke vacum pull-off) which has vacum to the choke piston in the housing since it is the choke pull-off piston and it looks like maybe a plug or something is missing from the hole. Many older carbs before they used electric assist and electric chokes had the vacum that leaked past the piston go to a threaded fitting by the choke housing and that was hooked to a tube that ran down through the exh manifold and back to the carb airhorn as it pulled fresh air from the carb airhorn down through the exh manifold where it heated the air and then it was pulled into the choke housing to heat the choke coil as the eng heated up. But this carb looks to be set up with the full electric choke and does not use the heat line like they used years ago but with the choke piston in the housing it still has vacum in the housing to the choke piston to open the choke some when started. My guess without a better look is a plug should be in the hole. Ron
Re: Hole in Carb: Vac leak HELP! What is this? [Re: 383man] #2011605
02/14/16 04:34 AM
02/14/16 04:34 AM
What Ron said, you gotta plug that vac leak
Re: Hole in Carb: Vac leak HELP! What is this? [Re: 383man] #2011624
02/14/16 10:26 AM
02/14/16 10:26 AM
Slidell, LA
Plum440 Offline OP
Plum440  Offline OP
Slidell, LA
Thanks Ron!! Funny, on my screen the picture isn't upside down.
A couple of Jeeps…
Re: Hole in Carb: Vac leak HELP! What is this? [Re: Plum440] #2011642
02/14/16 11:12 AM
02/14/16 11:12 AM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Thanks!
There should be a welch plug in that hole. And a rubber o ring between the choke housing and carb body.
Re: Hole in Carb: Vac leak HELP! What is this? [Re: Plum440] #2011644
02/14/16 11:22 AM
02/14/16 11:22 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
the 1406 carb on my dual quads has that hole, from the factory, and it works great.
