Re: Doing a cam swap for a customer, Rockers dont oil now [Re: Moparnut426] #2014002
02/17/16 03:53 PM
02/17/16 03:53 PM
Finally a HUSKER again
Moparnut426 Offline OP
Rapidrobert, Its oiling, its filling the shafts, I am currently modifying the rockers to aid in oiling. I spoke with another member on here who has dealt with oiling issues with crane rockers and Im going to make a channel to guide the oil to the feed holes in the rockers.
Re: Doing a cam swap for a customer, Rockers dont oil now [Re: Moparnut426] #2015018
02/18/16 10:54 PM
02/18/16 10:54 PM
thank you for the heads up on the rocker/cup oiling as I need to check/address that myself on the circle track 360 & I mighta just assumed it was good (when there is adequate oil in the shafts) if you had not jogged my brain
