Re: Electrical Question: Turn Signal Flasher
[Re: fal3]
#2011301
02/13/16 08:17 PM
02/13/16 08:17 PM
Posts: 43,163 Bend,OR USA
Cab_Burge
You have the basics correct , use your volt meter on the headlight switch to trouble shoot it It may be the switch or it might be in the bulkhead connector on the firewall or in the under dash wiring harness Let us know what you find
[Re: fal3]
#2011346
02/13/16 09:16 PM
02/13/16 09:16 PM
Posts: 253 Pasadena, Texas
fal3
Pasadena, Texas
Update 3: pulled headlight switch, connected to battery (12 volt this time), grounded switch, put meter box to all connectors, measured a consistent 12.5 volts at all connections; had switch on and off-same readings. One item I noticed, when adjusting the switch to brighten or dim the instrument panel, there was no change in the volts. I'm thinking that there should've been because it is a rheostat switch (I think I'm right on calling it this). I'm calling it quits for today. There's a margarita calling my name. Please continue to post suggestions. I'll be logged on in the AM. I want this car running. Having beautiful weather here in Texas, and I want to get out and enjoy it. 383man & Cab_burge, thank you for your replies and words of encouragement. A final note: I'll purchase a turn signal flasher. I take it that they are easily obtained from the local parts houses.
[Re: fal3]
#2011427
02/13/16 11:20 PM
02/13/16 11:20 PM
Posts: 5,813 ohio
ruderunner
ohio
This almost sound like a ground problem but with human interference, that is speculation.
Stop trying everything and anything, you'll just drive yourself nuts.
Let's break this down to systems. Stumpy is right, jumper the brake switch, what happens?
Yes he's right about the switch not always activating the park lights but I'm not sure what year that changed.
Stumpy is also right thyatvthe park fuse is hot on both sides when the headlight switch is set to park.
Short version, look for wires and connections you may have bumped while changing the master. It's more likely that you did something than wires crossed whom you changed the master.
Angry white pureblood male
[Re: fal3]
#2011442
02/13/16 11:39 PM
02/13/16 11:39 PM
RapidRobert
I know have turn signals, but parking lights and brake lights still do not work. Suggestions, please. take off the DR kick panel to access the connectors behind it. (1) Park light power originates in the HL switch then goes to the fuse box then down to the connector behind the kick panel for the rear park lites and to the bulkhead for the front park lites. (2) the brake light pedal switch is hot all the time (the pink wire) & this pink wire originates at the fuse box then goes to that switch & the white wire from the pedal switch goes to the TS switch assy in the column, then out from there down to the kick panel connector. (from the kick panel rearward for the brake lights you are good cuz the flashers are working). seperate the column TS pull apart dangling connector under the column and there should be continuity between the "in" wire from the brake light switch and the (2) "out" wires to the rear brake lights (with the stalk in neutral) this will elim or confirm the TS sw assy as the culprit ( www.mymopar.com will have the colors for you). Grab your VOM & this'll get you started. Holler when you can EDIT I missed Runners and Stumpys excellent advice
[Re: fal3]
#2011954
02/14/16 08:15 PM
02/14/16 08:15 PM
fal3
Pasadena, Texas
Update 4: replaced the turn signal flasher and the signals work well-strong and lights are bright both in dash and front and rear. Replaced emergency flasher, still have no emergency lights. Still have no parking lights or brake lights. Pulled brake light switch from pedal-put meter box to it (the connector w/ pink wires), have .06v going to it. Checked fuses, these are the numbers: instrument fuse-light switch off(measured from both ends of fuse)0.0/0.0vs; light switch on.01/.01 Taillight fuse-light switch off 11.5v (side of fuse closest to dash)/.07v (side of fuse closest to engine); light switch on 11.5v (side of fuse closest to dash)/.01v (side of fuse closest to engine) Some questions asked: yes, front parking lights go out when headlights are on. Checked all connections to see if I pulled something lose-connections good. Agree, this is human error, just can't figure out where I went wrong; if I pulled a ground loose, IDK where it is. The space is barren where the master cylinder and braked pedal linkage is. Checked bulkhead connector in engine compartment and under dash-no loose wires or wires pulled loose. Even checked behind master cylinder to see if maybe I pinched wires between MC and body. I started thinking voltage limiter got shorted, but then turn signals wouldn't (correct, I think).
[Re: fal3]
#2012002
02/14/16 09:44 PM
02/14/16 09:44 PM
Posts: 5,813 ohio
ruderunner
ohio
If I'm understanding your description of your voltage tests at the fuses, your brake light fuse is blown.
Fuses should have the same voltage on both ends, they aren't switches or loads.
Change some fuses. I bet you shorted the brake light wires while fooling around under the dash.
Also, don't the 4 ways get power through that same fuse?
Edit. Just saw your test with the jumper wire, you have confirmed a bad fuse. Basically you made your brake lights a test light.
[Re: fal3]
#2016986
02/22/16 12:01 AM
02/22/16 12:01 AM
RapidRobert
so the fuses had continuity but not enough flow? that one mighta thrown me; I'm glad it is all good now for you now
