Re: Done with Champion plugs
[Re: Hyper Henry]
#2011155
02/13/16 04:27 PM
02/13/16 04:27 PM
dartman366
Mt. Vernon, Ohio
I have run Autolites for years, even the one's made in mehico with excellent results, switched to NGK's a couple of years ago and have just as good of results with them, standard Champion's used to be a good plug but seem to have gone down hill a number of years ago, I ran the Champion racing plug for a while and had sucess with them too but they are harder to find around here, so I went back to Autolites.
[Re: Hyper Henry]
#2011277
02/13/16 07:29 PM
02/13/16 07:29 PM
Posts: 8,186 Plymouth, MI
Blusmbl
Plymouth, MI
I have had less than stellar luck with Champions and Autolites. On 2 different occasions I put a new set of Autolites in a car I'd owned and the engine had a miss immediately afterward. Put the old plugs in and it cleared up.
I've never had bad luck with NGK's, in everything from race cars to lawn equipment.
[Re: Hyper Henry]
#2011321
02/13/16 08:45 PM
02/13/16 08:45 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
I would correct the air fuel ratio first, jetting or fuel map, to stop the plug fouling first and go from there ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) I've used all three brands of spark plugs with good results with all of them ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) On your deal with Autolites on the street I would start with Auolite # 3924 resitor plugs or thier # 3911 non resitor race plugs ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) IHTHs
[Re: Cab_Burge]
#2011336
02/13/16 09:12 PM
02/13/16 09:12 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
I run Denso plugs in my engine. I had my heads out on the bench at work and had a Tundra in my rack getting a tune up. So I screwed on of the Denso Iridium plugs from the Tundra into my Indy head and they looked good in the chamber. So I snagged a set out of parts just to break in my 493 and surprise!!! they are still in there after about 6 years. They don't foul and never miss a beat EVER!!! I'll never use another brand plug in my engine.Been using Denso plugs in all my engines since I've been an import technician ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Hyper Henry]
#2011438
02/13/16 11:34 PM
02/13/16 11:34 PM
Cab_Burge
# 3924 for the street car, 3911 or maybe 3910 for the race car ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) Try the 3911 first and go from there ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) Summit stocks and sells them also ![work work](/ubbthreads/images/graemlins/custom/work.gif)
