A body Kelsey Hayes lower balljoint part # 7183/7184 #2011082
02/13/16 02:34 PM
02/13/16 02:34 PM
Minnesota USA
Dart6pak Offline OP
Dart6pak  Offline OP
Minnesota USA
I am rebuilding a set of Kelsey Hayes 4 piston brakes and the lower balljoints are stamped 7183 and 7184---when I search the part # nothing shows up on the web --are they correct for 68-72 A body
Re: A body Kelsey Hayes lower balljoint part # 7183/7184 [Re: Dart6pak] #2011085
02/13/16 02:39 PM
02/13/16 02:39 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Don't know about part numbers, but easy to tell if they are drum brake, or disc brake lower ball joints.
Measure the mounting bolt hole diameters.
1/2 inch, Drum brake.
9/16 inch, Disc brake.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: A body Kelsey Hayes lower balljoint part # 7183/7184 [Re: hemi71x] #2011089
02/13/16 02:43 PM
02/13/16 02:43 PM
Minnesota USA
Dart6pak Offline OP
Dart6pak  Offline OP
Minnesota USA
thanks for the reply---they bolt up properly with 9/16 bolts--it is the part # that is bugging me because all replacements only ave 3 #'s
