freshening up the 408 #2010857
02/13/16 12:12 AM
02/13/16 12:12 AM
Finally a HUSKER again
Moparnut426 Offline OP
Who on here sells those High Performance gasket sets? Also planning on mounting a remote oil filter since my headers are tight.
Whos Rod bolt gauge would you recommend
Last oil change I saw a little coppery looking glitter in the oil, and I checked the bronze gear on the Distributor drive, its like new. So I fear a little bearing wear. It holds 80+ oil pressure down the highway and 30 at idle so I dont think theres muck bad at all.
Kasey
Re: freshening up the 408 [Re: Moparnut426] #2010991
02/13/16 10:41 AM
02/13/16 10:41 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
There's a member on here who sells superperformance gaskets, can't rember his handle. He's on here regularly so he should pipe up soon. If you go to their website (superperformanceproducts.com) his red Barracuda is on the cover page of the website. They're a sponsor on here as well
Re: freshening up the 408 [Re: WO23Coronet] #2011022
02/13/16 12:13 PM
02/13/16 12:13 PM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
Call Todd Marsh ar Marsh Performance.
http://www.mopartsracing.com/
Marsh Performance
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: freshening up the 408 [Re: Moparnut426] #2012467
02/15/16 03:20 PM
02/15/16 03:20 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
The member that I was referring to in my post that works for superperformance is roadhazard
Re: freshening up the 408 [Re: WO23Coronet] #2012594
02/15/16 06:05 PM
02/15/16 06:05 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Kasey, thanks for thinking of us!
WO23Coronet I appreciate the you helping him with some direction to us.
As Wade said, Todd at the Moparts Connection/ Marsh Performance is a good source for our gaskets.
Appreciate the support guys! thumbs
