Re: 440 Compression Curiosity
[Re: DaytonaTurbo]
#2010407
02/12/16 11:57 AM
02/12/16 11:57 AM
Posts: 7,664 IN
ahy
IN
You'd need to lose about 1.0 of compression off that combo for that to co-operate with pump gas and a mild street cam. Perhaps some D-dished pistons or better yet aluminum heads. Agree!
[Re: dvw]
#2010469
02/12/16 02:33 PM
02/12/16 02:33 PM
RapidRobert
.039 is good quench but beware the thicknesses of head gaskets can be way off from the stated dimention (mike an old one of same type). You want the DCR reasonable enough for your octane so you can run an aggressive ign curve. On the aluminum there was a good discussion here (if I read it right) on that & that other than the weight savings off the front that there is no real magic as in more power from alum VS cast iron but you would get closed chambers and likely better ports (plus potential for more porting). Just me If the octane is set in stone (& proportioning in race gas in a DD gets old fast) I would lower the SCR/keep the quench (if you can with your piston/gasket selection) then max out the ign and ESPECIALLY get the CORRECT cam in there for your (driving) tastes
[Re: BSB67]
#2010861
02/13/16 12:19 AM
02/13/16 12:19 AM
RapidRobert
adv the cam 4 deg. retune the dist subsystems. the exhaust is typically a restriction that needs reworking
[Re: elmor353]
#2010918
02/13/16 02:22 AM
02/13/16 02:22 AM
RapidRobert
mandrel bends? loud (unrestricted) muffs?. uncorking the collectors & going out for a spin will tell you if a restriction from there rearward is holding you back excessively
[Re: elmor353]
#2011083
02/13/16 02:38 PM
02/13/16 02:38 PM
Posts: 43,317 Bend,OR USA
Cab_Burge
Right now I'm running a 67 440 w/stock flat tops, .070 in the hole, #346 heads with .020 steel head gaskets. Calculates to 9:23-1. Eddy RPM intake, 440 Source distributor w/no vacuum advance, Summit 6401 cam and matching Crane spring. It runs fine on 89 octane w/no quench. It pulls pretty good now, I just want to build something with more oomph and I'm on a tight budget. I have a small block factory hi stall converter behind it and I want to keep my 3:23 gears to cruise. Any suggestions to improve on what I have would be appreciated. Did you CC a combustion chamber in both heads? If not you should as those heads stock are close to 91.0+ on all the ones I've check. I'm thinking your true measured compression ratio is probaly around 8.5 to 1 or less ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Have you jetted the carb. and maxed out the timing curve yet? If not do that also ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) Little things add up quiclky to making a lot more power ![work work](/ubbthreads/images/graemlins/custom/work.gif) What size and brand carb are you using?
[Re: dogdays]
#2011307
02/13/16 08:23 PM
02/13/16 08:23 PM
Cab_Burge
The factory BB "346" heads are one year only, 1971, and they are big in CC from the factory ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) As far as your post I didn't see him wanting to change to the factory close chamber heads on his original post, shame on me ![blush blush](/ubbthreads/images/graemlins/custom/blush.gif) Elmor, I wouldn't make the compression ratio much above 9.5 to 1 with any iron wedge head, quinch or no quinch on todays pump swill ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
