2002 ram 4.7 what would cause this #2009964
02/11/16 05:43 PM
02/11/16 05:43 PM
nc
E
earthmover Offline OP
E
nc
What would cause this guys..4.7 2002 ram 1500 236xxx miles oil changes regular just out the blue driving ...
Re: 2002 ram 4.7 what would cause this [Re: earthmover] #2009971
02/11/16 05:59 PM
02/11/16 05:59 PM
places
79powerwagon Offline
places
You mean besides the quarter million miles on it and a hidden casting defect finally showed thru?
Bravo on getting that kind of mileage out of that engine. I'm a fan of them, but many here are not...
Re: 2002 ram 4.7 what would cause this [Re: earthmover] #2009972
02/11/16 05:59 PM
02/11/16 05:59 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The rocker just sits there unsecured by anything but hydraulic pressure in the lifter, if the lifter bleeds down they fall off, the lobe hits em and can break all kinds of thing or not harm a thing. Once one falls off the rest are liely to do the same and just replacing them is not enough it just starts sno-balling from there.
Re: 2002 ram 4.7 what would cause this [Re: HotRodDave] #2009977
02/11/16 06:04 PM
02/11/16 06:04 PM
nc
E
E
nc
So basically I have to replace the head lifters to fix..smh I was planning on trading this thing in the next few weeks for a 3500 ..just my luck..thanks guys
Re: 2002 ram 4.7 what would cause this [Re: earthmover] #2010847
02/12/16 11:56 PM
02/12/16 11:56 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Yeah gonna need a new head, I probably have one as I have bunches of blown up 4.7s around the shop, you could bolt one on and hurry down and trade it in on your test drive. I try to warn people about this but no body trusts me... glad you got that many miles as it is kinda un usual.
Re: 2002 ram 4.7 what would cause this [Re: HotRodDave] #2031153
03/14/16 08:21 PM
03/14/16 08:21 PM
nc
E
E
nc
Ok guys I think I'm going to put heads new gaskets and bolts on this thing..with 24xxxx miles should I just be looking to get rid of it or with the new top end I should be ok..was going to buy a diesel but think I'm going to wait and look into a small rv..
Re: 2002 ram 4.7 what would cause this [Re: earthmover] #2031765
03/15/16 04:59 PM
03/15/16 04:59 PM
nc
E
E
nc
Is there anything else I should address while in here doing the top end
Re: 2002 ram 4.7 what would cause this [Re: earthmover] #2031998
03/15/16 11:48 PM
03/15/16 11:48 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
New lifters if you think there is any chance you might keep it. Timing chain tensioners, guides, maybe an oil pump. I can not find any good 4.7 heads in my stash so I am scrapping them all. I do have one complete engine coming out with blown head gaskets and bottem end is out, when I get the new engine swapped in I will pull the heads and see if they look useable but not gonna be in the next few days.
Re: 2002 ram 4.7 what would cause this [Re: HotRodDave] #2032727
03/16/16 11:00 PM
03/16/16 11:00 PM
nc
E
E
nc
Yes lifters will be new..sounds like I might just be better to get another truck..
