70 Roadrunner Seat Belt Question.
#2009740
02/11/16 09:53 AM
02/11/16 09:53 AM
Posts: 2,179 Walton, Indiana
TimS
Walton, Indiana
My 70 Roadrunner, I've owned going on 30 years, has never had the correct seat belts in the front. I've owned lots of 69's and those had the male part of the clasp attached about halfway up the lap belt for use on the shoulder belts for a bench seat car. Same as my 69 Formula S bucket seat car. Would this be the same for a 70 model B Body with bench?
Thanks.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor 1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic 1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow 1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top 2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue 2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black 2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
Re: 70 Roadrunner Seat Belt Question.
[Re: TimS]
#2009743
02/11/16 10:04 AM
02/11/16 10:04 AM
Posts: 1,386 Philadelphia PA
Pynzo
Drugs are bad
Drugs are bad
Philadelphia PA
I've got the OEM belts in my '70 Bee. Bench seats had two separate belts (driver side 2,passenger side 2) with female end for the lap and shoulders. Male ends at the roof and retractable at the hip.
[Re: NANKET]
#2009882
02/11/16 03:14 PM
02/11/16 03:14 PM
TimS
Walton, Indiana
Do you have buckets & console, or buckets with a buddy seat, or a bench seat. It will change what you have. I have the bench seat.
[Re: Pynzo]
#2009885
02/11/16 03:19 PM
02/11/16 03:19 PM
TimS
Walton, Indiana
I've got the OEM belts in my '70 Bee. Bench seats had two separate belts (driver side 2,passenger side 2) with female end for the lap and shoulders. Male ends at the roof and retractable at the hip. Sounds like what you have is what I have now as well. So the 69's were opposite. Female end at the roof that attach to the center of the lap belt to a male end were the 70's had actual separate belts for the lap and shoulder. 2 female belts on each side. Do you have belts for a 3rd person up front also in the middle? Mine has that. I've got belts sticking out everywhere it seems.
[Re: NANKET]
#2010172
02/11/16 10:37 PM
02/11/16 10:37 PM
Posts: 3,528 Lansing, MI
70gtx440dana
Lansing, MI
I want to add that the shoulder belts are stored in the clips along the roof, the female buckle end goes behind them also. The 70 does not have the piece under the visor mount to hold the end of the belt. Pretty sure you meant to say "male" end for the shoulder belts is attached along the roof. The 69 models had the female shoulder belt....70 model year went to male shoulder belt.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: NANKET]
#2010214
02/11/16 11:41 PM
02/11/16 11:41 PM
TimS
Walton, Indiana
I want to add that the shoulder belts are stored in the clips along the roof, the female buckle end goes behind them also. The 70 does not have the piece under the visor mount to hold the end of the belt. I wonder why Mopar changed the 69 way of doing these belts. Seems allot more efficient use and stowage of them than in 70. Guess I do have the right ones in my car after all.
[Re: TimS]
#2010218
02/11/16 11:46 PM
02/11/16 11:46 PM
TimS
Walton, Indiana
Seems crazy though that I have 3 female ended belts along the seat for the driver. 1 for the lap, 1 for the shoulder and one for a center passenger.
[Re: NANKET]
#2011619
02/14/16 10:02 AM
02/14/16 10:02 AM
TimS
Walton, Indiana
I want to add that the shoulder belts are stored in the clips along the roof, the female buckle end goes behind them also. The 70 does not have the piece under the visor mount to hold the end of the belt. Yes I do have the clips along the roof you are speaking of. So I'm in good shape it appears. I actually have what I'm supposed to have in this 70. Compared to a 69, it just seems a bit cluttered with 3 belts lying on each side of the seat. Thanks all for help!!
