A couple more 4dr to 2dr parts interchange ?s
#2009278
02/10/16 03:31 PM
02/10/16 03:31 PM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
I need to get back to parting out the 4 door coronet I have sitting in my driveway. I grabbed the things I needed and obvious stuff (fenders, hood, power steering box,etc). I do have a couple of questions. Are the headline bows unique to 4 door. They look to have some of the same colors on the ends as a set of 2 door bows I had. Door latch mechanisms- I know rods from handle is shorter, but is the mechanism the same? It appears the latches that mount in the door jambs are the same. I will grab those. Window crank mechanism? I haven't removed the plastic to look into the doors but was wondering if they window mechanisms were the same.
Thanks.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
Re: A couple more 4dr to 2dr parts interchange ?s
[Re: RoadRunner]
#2009416
02/10/16 06:25 PM
02/10/16 06:25 PM
RoadRunner
69 Coronet. Sorry about that.
[Re: RoadRunner]
#2009433
02/10/16 07:19 PM
02/10/16 07:19 PM
Posts: 75,023 U.S.S.A.
JohnRR
U.S.S.A.
Door latch stuff is the same , shorter rod as you note , I can't really say on the other stuff but I don't think the window mechs are the same.
[Re: RoadRunner]
#2009541
02/10/16 10:37 PM
02/10/16 10:37 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
The 69 4-door front latches are the same as 68 2 door. 69 2 door latches are different due the inside lock handle being move forward. Rear latches are different than front latches. Headlines bows are 4-door only. Front bows will work but the rear bows won't.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
