Transmission seal size? #200953
01/22/09 01:58 PM
01/22/09 01:58 PM
Inver Grove Heights MN
74RR Offline OP
74RR  Offline OP
I just installed my fresh 727B with a Dynamic convertor.Now I'm wishing I would have measured the seal and the snout on the convertor to make sure they are the same size and will not leak. Are there different size seals for 727's?
Re: Transmission seal size? [Re: 74RR] #200954
01/22/09 02:37 PM
01/22/09 02:37 PM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
All 727s have the same converter hub size (converter hub diameter ~ 1.875").
John
Re: Transmission seal size? [Re: DusterW2] #200955
01/22/09 02:51 PM
01/22/09 02:51 PM
74RR Offline OP
74RR  Offline OP
That takes a load off my mind.Thank you.
