Re: Use of muriatic acid.... [Re: Apollo 13] #2008408
02/09/16 03:56 AM
02/09/16 03:56 AM
Maysville, Kentucky
Apollo 13 Offline OP
Maysville, Kentucky
Bumping this back up.....
Indcontrols....What type of device for water pressure. Like a deck pressure washer or ? And how long was this process.
Rebel....How long was it before you saw any results. I have a place that can hot tank it. Do you think that would do it over the course of a few weeks...or ?
Thanks in advance for all the help.
If you don't start it , you don't have to end it.
Re: Use of muriatic acid.... [Re: Apollo 13] #2008436
02/09/16 09:48 AM
02/09/16 09:48 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
5-6 months. if its going to work you should see something in the water in a few weeks
Re: Any and All Ideas on removing engine block filler ? [Re: rowin4] #2008511
02/09/16 01:14 PM
02/09/16 01:14 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Originally Posted By rowin4
Just a note on the muriatic acid. As it might eat away the hard block slowly it will also eat away at the block material at a faster rate. Also if anyone is thinking of using muriatic acid for rust removal , don't do it in your garage, the fumes will kill you before you can get out, also the fumes will rust every piece of bare metal in the garage. Do it out side with a good breeze blowing away from anything that you might like to keep, also wear rubber gloves and eye protection . I other words, muriatic acid is some bad $hit.
That's new to me, I have used MA for years on all types of steel-cast iron, never saw any metal removed, what looked like metal removed was what the rust had allready eaten. Always use outside keep in closed container.
For the OP, put a few drops in there and see what happens, never know unless tried.
Re: Any and All Ideas on removing engine block filler ? [Re: Apollo 13] #2008560
02/09/16 02:29 PM
02/09/16 02:29 PM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
I wonder if soaking in vinegar would break it down?
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: Any and All Ideas on removing engine block filler ? [Re: BBR] #2008562
02/09/16 02:32 PM
02/09/16 02:32 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Well, if not at least it will be pickled. laugh2
Re: Any and All Ideas on removing engine block filler ? [Re: dartman366] #2008645
02/09/16 04:42 PM
02/09/16 04:42 PM
dogdays Offline
dogdays  Offline
Muriatic acid is also known as hydrochloric acid, it's what helps digest your food in your stomach.
Scare stories aside, it can be rinsed out of a block and it is used to clean scale out of a block, this is quite common. Of course if the block in question has a rusty pinhole, the acid will find it.
It is used to etch concrete. It reacts with the alkaline based cement. Will it work on block filler is a good question and depends on what the block filler is primarily made of.
The factors for metal removal are concentration, time and temperature. Increase any of them and metal removal increases.
R.
Re: Any and All Ideas on removing engine block filler ? [Re: Apollo 13] #2008846
02/09/16 10:20 PM
02/09/16 10:20 PM
Wild West
M_D Offline
M_D  Offline
Wild West
If the acid didn't at least eat away enough filler in a certain time frame (before the block started to significantly suffer), it might be hard to rinse and neutralize acid that found its way into deeper voids between the filler and block.
If I had the block and seriously wanted to find out I would try to remove a sample piece of the filler and do some testing outside the block.
Re: Any and All Ideas on removing engine block filler ? [Re: Apollo 13] #2369722
09/12/17 10:55 PM
09/12/17 10:55 PM
Bill1234 Offline
Bill1234  Offline
So, what is the end of the story? Did you get the filler out or buy the block or just build the engine?????
Re: Any and All Ideas on removing engine block filler ? [Re: Bill1234] #2369958
09/13/17 11:53 AM
09/13/17 11:53 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have a buddy that has a 455 Pontiac block 3/4 filled and drives it on the street all of the time. It runs cooler than any of my Mopars every have.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Any and All Ideas on removing engine block filler ? [Re: 6PKRTSE] #2369982
09/13/17 12:35 PM
09/13/17 12:35 PM
an8sec70cuda Offline
Water temp will be cooler...common for a filled block. But I bet the oil temp is up there.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Any and All Ideas on removing engine block filler ? [Re: an8sec70cuda] #2370393
09/13/17 10:44 PM
09/13/17 10:44 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
iagree
Re: Any and All Ideas on removing engine block filler ? [Re: an8sec70cuda] #2370963
09/14/17 10:24 PM
09/14/17 10:24 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
. [/quote]
Water temp will be cooler...common for a filled block. But I bet the oil temp is up there. [/quote]
Exactly, my Hemi is filled and it runs cool but after driving around and sitting in any traffic, the thing is just huffing oil out of the valve cover breathers.
Re: Any and All Ideas on removing engine block filler ? [Re: Apollo 13] #2370992
09/14/17 11:10 PM
09/14/17 11:10 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
My half fill 528 will sit in traffic all day in summer but gets up a bit on the highway
1963 Plymouth Max Wedge
1971 Barracuda
Re: Any and All Ideas on removing engine block filler ? [Re: Apollo 13] #2371004
09/14/17 11:33 PM
09/14/17 11:33 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
a vibratory table is the only way I have seen it done successfully
