Dana 60 Strange main cap fittment
#2008073
02/08/16 06:28 PM
02/08/16 06:28 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I bought a set of Dana 60 strange aluminum main caps and they need to machined to fit. I got them machined to the right spec on the bore but it seems the edge of the new cap and the edge of the case dont line up just perfect. I put the factory caps on an it seemed to fit the same way. Anyone ever seen this be for?
67' charger 499 RB
10.57 at 127
Re: Dana 60 Strange main cap fittment
[Re: dragram440]
#2008349
02/09/16 01:28 AM
02/09/16 01:28 AM
Posts: 43,127 Bend,OR USA
Cab_Burge
I bought a set of Dana 60 strange aluminum main caps and they need to machined to fit. I got them machined to the right spec on the bore but it seems the edge of the new cap and the edge of the case dont line up just perfect. I put the factory caps on an it seemed to fit the same way. Anyone ever seen this be for? There is absolutely no way in the world that I would suggest, let alone use, alumunim caps on a drag race rear end Billet steel, YES
[Re: Cab_Burge]
#2008383
02/09/16 02:29 AM
02/09/16 02:29 AM
Posts: 581 Boise Idaho
65coronet500
Boise Idaho
[/quote] There is absolutely no way in the world that I would suggest, let alone use, alumunim caps on a drag race rear end Billet steel, YES [/quote] I would Second that !!!
All steel 3800 lbs with me in it 65 Coronet 451 CID Indy 440-1 heads by Dwayne Porter racing heads . ..... 10.31 @ 129.4 mph 1.40 60 ft ALL MOTOR!!!!
[Re: sgcuda]
#2008575
02/09/16 02:49 PM
02/09/16 02:49 PM
dragram440
bigfork mn
I've had Strange caps in my Dana since the 80's. Has run high 9's. Planning on running mid 8's.
This is what I bought. They say they are much stronger then the factory steel cap. Yes it doesn't line up just perfect where the race sits inside. It's not way off but it not a perfect fit. I got them machined down to the spec that strange calls for on the bore diameter.
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#2008591
02/09/16 03:33 PM
02/09/16 03:33 PM
dragram440
bigfork mn
I called Strange and they say they are far superior to the factory caps. I also got a cover with the load bolts so that should also help.
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#2008650
02/09/16 04:51 PM
02/09/16 04:51 PM
Cab_Burge
The Dana 60 in my Cuda has dual Mark Williams steel caps and 40 spline M.W. aluminum spool and axles, it had a set of Pro 5.86 gears in it when I bought and a LPW aluminum cover with the load bolts in it as a roller. I changed the gears and spool to a set of 4.56 with a Strange Engr. steel spool This car has reportily ran 7.60 at 184+ MPH weighing 2500 lbs with the driver and a KB aluminum B1 motor with a blower running methanol, all the rear end parts look excellent I figure that no one would make or sell aluminum caps for a rear end in anything other than sport car or extreme high speed racing where there is very little shock to the drive train
[Re: dragram440]
#2009461
02/10/16 08:19 PM
02/10/16 08:19 PM
dragram440
bigfork mn
I already bought the strange caps and fitted them to the case. Not sure how you would machine the caps attached to the housing.
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#2009500
02/10/16 09:11 PM
02/10/16 09:11 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Line bore, that's how. Probably impractical.
The cap needs to line up.
[Re: Leon441]
#2009841
02/11/16 02:03 PM
02/11/16 02:03 PM
dragram440
bigfork mn
The cap needs to line up. The caps are oversized and have to be machined off of the mating surfaces.
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#2009868
02/11/16 02:45 PM
02/11/16 02:45 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
No you can't line bore this application, NOR would line boring them achieve what you're trying to do. Nor can you machine them with the caps on the case...... Way wrong.
To the OP: I'm working with an 8-3/4", not a Dana, But my factory caps were as I believe you are describing. The mating surfaces, and the threads fit and aligned, but the edges of the caps hung over the edge of the case mating surface and were nowhere near looking like a matched set. The MW steel cap I installed on mine actually fit the case much better, but still not perfect.
Is this what you're describing? If so, I think its inconsequential. What's important is the that the bore is correct, and that the threads align when the cap is centered on the bolt/hardware. I'd say move along, you're fine.
[Re: dragram440]
#2009877
02/11/16 03:04 PM
02/11/16 03:04 PM
Leon441
Lynchburg, VA
You wouldn't want to. Especially with the axles tunes in housing.
I was sort of being sarcastic. Dana bored the bearing race fit when new.
You machine the thick cap down till the bore is correct. Now you have misalignment at the parting line. Is it the cap or the bolt holes to bore in the housing to blame?
Post a pic and someone can tell you what's wrong or how to correct.
