Re: 360 Help
[Re: elmor353]
#2008390
02/09/16 02:36 AM
02/09/16 02:36 AM
RapidRobert
some used mag heads (& required valvetrain) & redrill for LA pattern. there are some 30 over 360 pistons on ebay for ~132 (iirc) with free shipping EDIT $170.32 to your door
Re: 360 Help
[Re: Baxter61]
#2008709
02/09/16 06:40 PM
02/09/16 06:40 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
how far you wanna drive? theres a guy on Portland CL with a brand new set of KB107 +.030 for $150, plus theres intakes and guys up here with Comp 268H type cams, that in my mind would be a perfect built for that wagon. A couple years back I bought a 318/360 #2176 intake mainfold from you and had Dustin Ward pick it up from you while my check was still on the way. That manifold is on my daily driver now and I have a truck 360 in my shop that is looking to be swapped in place of the 318. I bought it from another Mopar dude, it was supposedly rebuilt once before (it is pretty clean inside) but I need to pull the heads to check the existing bore size. I built an E-58 360 for a '74 D100 a long time ago and used Badger 9.0 cast pistons and the E-brock Performer cam & kit, with the same manifold, with headers and a single 3" exhaust. I wish I still had it, but I traded it to my oldest son and he essentially gave it away.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
Re: 360 Help
[Re: Polarapete]
#2008906
02/09/16 11:27 PM
02/09/16 11:27 PM
Posts: 869 Keizer, Oregon U.S.A.
elmor353
The guy I'm doing this for has a gazillion vehicles on his farm. He's got an 89 3/4 ton van with a 360 roller motor in it. It sat for years, but, I had it running a couple of years ago. Sounded great, but, then something went belly up in the injection system. I think with a Hughes Whiplash cam, aftermarket intake, headers, converter and gears, it would make him a happy camper. I haven't checked, but, I'm thinking this engine should have 308 heads on it.
