Got a 66 D700, how to change out the Dayton wheels? #2007939
02/08/16 03:10 PM
02/08/16 03:10 PM
Round Lake Beach, Illinoisy
Rhinodart Offline OP
Rhinotruck
Rhinotruck
I just acquired a 1966 D700 ramp truck and would like to change-out the Dayton style wheels for Budd's, is there a way to do it without changing out the axles? I have seen this done on the Snake and Mongoose haulers, but don't know how they accomplished it. shruggy
JB Rhinehart, Realist
A-Body's RULE!
Re: Got a 66 D700, how to change out the Dayton wheels? [Re: Rhinodart] #2007940
02/08/16 03:14 PM
02/08/16 03:14 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
No real help for you, but curious why you want to change out the dayton wheels? We still see some older units with the dayton's come through our shop and they're still doing fine on OTR units racking up the mileage. Most larger shops still stock components for dayton wheels and hubs.
Re: Got a 66 D700, how to change out the Dayton wheels? [Re: Rhinodart] #2007957
02/08/16 03:31 PM
02/08/16 03:31 PM
places
79powerwagon Offline
places
I personally like the look of the original wheels. smile
See, once again, I am of little use (or help)!
Re: Got a 66 D700, how to change out the Dayton wheels? [Re: Rhinodart] #2007973
02/08/16 04:12 PM
02/08/16 04:12 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
not a clue, but a great looking truck. I like the shiney wheels, but the Dayton's are getting rare, I'd leave'm on.
1981 Dodge D150 360 auto
Re: Got a 66 D700, how to change out the Dayton wheels? [Re: basketcase] #2007989
02/08/16 04:31 PM
02/08/16 04:31 PM
Rhinotruck
Rhinotruck
I was just perusing the web and there is a company local that makes covers for Daytons. Saw some cool 2 and 3 tone painted Daytons too, may have to change my mind, plus ti is MUCH cheaper to keep what I got... work
A-Body's RULE!
Re: Got a 66 D700, how to change out the Dayton wheels? [Re: Rhinodart] #2008041
02/08/16 05:43 PM
02/08/16 05:43 PM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
The main reason that people change them out is because most places don't like dealing with split rim wheels when the tires need changed.
Re: Got a 66 D700, how to change out the Dayton wheels? [Re: Rhinodart] #2008057
02/08/16 06:06 PM
02/08/16 06:06 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
I think Accuride makes a rim that mounts on the dayton spokes and isn't the split rim design. takes modern tubed tires. Just looking at this link 10 stud was an option for 600's and 700's you would most likely need to find a donor truck though.
Re: Got a 66 D700, how to change out the Dayton wheels? [Re: CTD5.9] #2008064
02/08/16 06:17 PM
02/08/16 06:17 PM
Rhinotruck
Rhinotruck
Wow, lots of options to try to figure out what weight capacities I have in this truck! runaway
A-Body's RULE!
Re: Got a 66 D700, how to change out the Dayton wheels? [Re: Rhinodart] #2008068
02/08/16 06:25 PM
02/08/16 06:25 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
Is there a metal plate with the GVW and such ratings rivetted either on the inside of the drivers door or on the jam. Might help with the ratings somewhat.
Re: Got a 66 D700, how to change out the Dayton wheels? [Re: Rhinodart] #2008201
02/08/16 10:16 PM
02/08/16 10:16 PM
Lehigh Acres, Florida
rickstershemi Offline
I would think a good heavy truck repair shop would be able to cross reference the parts needed for the swap and then hit the big wrecking yards for the parts to save $$$ The Budds sure do look nicer on those trucks.
Rickster
Re: Got a 66 D700, how to change out the Dayton wheels? [Re: rickstershemi] #2008294
02/08/16 11:55 PM
02/08/16 11:55 PM
IN
ahy Offline
ahy  Offline
IN
Nice looking truck. If the goal is tubeless tires, I'm pretty sure you can get tubeless rims (not split ring) to go with your current Dayton wheels... as several have mentioned, a heavy truck tire shop or repair shop could help. I have run that style wheel on a working truck with no particular issues.
Re: Got a 66 D700, how to change out the Dayton wheels? [Re: ahy] #2008316
02/09/16 12:21 AM
02/09/16 12:21 AM
Rhinotruck
Rhinotruck
A previous post talked about Accuride and they are local, and have the correct hoops for tubeless tires on Dayton hubs! There is also another local company that makes simulators for Daytons! Problem solved... up
http://www.realwheels.com/product/simulators-19-5/
A-Body's RULE!
Re: Got a 66 D700, how to change out the Dayton wheels? [Re: Rhinodart] #2008319
02/09/16 12:23 AM
02/09/16 12:23 AM
fredericksburg virginia
mopwrd340 Offline
mopwrd340  Offline
You can use tubeless rims i wouldn't want to mess with a split rim some tire shops won't mess with them and i don't think they're made anymore . As long as the ears are in good shape on the hubs i would get tubeless ones what size tire are you going to use .
Re: Got a 66 D700, how to change out the Dayton wheels? [Re: Rhinodart] #2008351
02/09/16 01:31 AM
02/09/16 01:31 AM
ND
dodgedon Offline
dodgedon  Offline
ND
We are still running 2 Dodge trucks. A 66 CT800 and a 75 CNT800. Both have Dayton wheels with no issues. The 75 needed larger front tires "16.00" so 22.5 tubeless wheels were used. Otherwise both trucks have 10.00 x 20's on them. I believe if you wanted Bud type wheels. The drums and spokes are replaced with hubs and drums. This sounds easy but you would have to find the right Diameter drum that would fit your spindle bearing hub and wheel bolt pattern.... I have seen Bud wheels on Dodge trucks like yours, but they were usually lighter models like D500 D600. Do you have any School bus bone yards? They seem to have bud type wheels usually.
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
Re: Got a 66 D700, how to change out the Dayton wheels? [Re: dodgedon] #2008371
02/09/16 02:00 AM
02/09/16 02:00 AM
Rhinotruck
Rhinotruck
I worked at an International dealer for the last couple of years before my new job in September so I have good local contacts. I think I will stay with the Daytons, leave the wheels and tires I have on it for now and buy new tubeless rims and tires as money allows. work Plenty of other things to do first, maybe a hydroboost brake system, and the interior needs completed. realcrazy
A-Body's RULE!
Re: Got a 66 D700, how to change out the Dayton wheels? [Re: Rhinodart] #2008407
02/09/16 03:51 AM
02/09/16 03:51 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
My D600 and W500 both have the Budd style wheels.
Nice score! Going to do something with it this decade lol?
I'd be interested to compare stickers on your D700 and my '67 D600.
Re: Got a 66 D700, how to change out the Dayton wheels? [Re: Jeremiah] #2008689
02/09/16 06:15 PM
02/09/16 06:15 PM
Rhinotruck
Rhinotruck
I probably won't get back out to the shop until Saturday to give the once over. The poor 92 Cummins ramp truck is probably hoping I will cut it lose now, as like you mentioned it has sat for a couple years now and really needs to be on the road... realcrazy
A-Body's RULE!
Re: Got a 66 D700, how to change out the Dayton wheels? [Re: Rhinodart] #2008701
02/09/16 06:32 PM
02/09/16 06:32 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
The D700 would enjoy a nice 12v Cummins swap! The Cummins might not enjoy the at best 6.14 gears though.
Re: Got a 66 D700, how to change out the Dayton wheels? [Re: Rhinodart] #2008706
02/09/16 06:36 PM
02/09/16 06:36 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I say put the running gear from the 92 into the 66, that would be a nice setup
Re: Got a 66 D700, how to change out the Dayton wheels? [Re: WO23Coronet] #2009128
02/10/16 10:56 AM
02/10/16 10:56 AM
Rhinotruck
Rhinotruck
Not ready to part this one out yet... tsk
A-Body's RULE!
