65 b body has tank strap #2007649
02/07/16 11:45 PM
02/07/16 11:45 PM
Madison Wi
NTOLERANCE Offline OP
Madison Wi
I need a pic of the gas tank strap where is bolts / threads in at the back of the car
Single strap. 65 coronet. I can't tell what's missing
Re: 65 b body has tank strap [Re: NTOLERANCE] #2007738
02/08/16 02:01 AM
02/08/16 02:01 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I looked thru all of mine and have none.
If I can get home in time tomorrow I'll take pics of where the strap J Bolt goes...
...FAFO...
Re: 65 b body has tank strap [Re: NTOLERANCE] #2007873
02/08/16 12:24 PM
02/08/16 12:24 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
Here are pics I can share from my '65 Satellite.
The strap obviously goes under and installs from front to back (front being at the axle and rear being at the filler neck behind the license plate).
The front (axle) end of the strap has the 'T' shape. This is the "dumb" end and goes into a slot on the subframe. You stick the 'T' in vertically and twists down horizontally into place.
At the rear is where the threaded parts go….
One piece is the threaded bolt with the flattened "mushroom head". The "mushroom head" of this bolt goes into the upside-down-pear-shaped hole on the subframe right under the filler neck pocket.
Then the threaded end that hangs down goes through the hole in the strap, and you put on the nut and tighten it up and it looks like this.
Come back here with any Q's.
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: 65 b body has tank strap [Re: NTOLERANCE] #2007887
02/08/16 12:59 PM
02/08/16 12:59 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
67 thats how it mounts.Just looked at my 65.Only one strap and a bolt with a head thats bent and flared out.Rocky
Chrysler Firepower
Re: 65 b body has tank strap [Re: NTOLERANCE] #2007930
02/08/16 02:52 PM
02/08/16 02:52 PM
Madison Wi
Madison Wi
Thanks guys. I don't have that bolt. And I didn't see that hole.
I'll make up a bolt and look again
Re: 65 b body has tank strap [Re: NTOLERANCE] #2008139
02/08/16 08:03 PM
02/08/16 08:03 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I may have that J bolt in all the stuff leftover from mine...it's probably easier to make than hassle with shipping... up
...FAFO...
Re: 65 b body has tank strap [Re: NTOLERANCE] #2008612
02/09/16 04:07 PM
02/09/16 04:07 PM
Albany, NY
Albany, NY
Just for detail's sake I'll mention that the factory put a layer of thick black/brown asphalt paper (like goes under roof shingles or siding on a house), on top of the tank before installing it.
This was to prevent corrosion by avoiding contact between the metal of the tank and the metal of the trunk pan or subframe.
Cheers,
- Art
