Hollow stem valves? #2007436
02/07/16 04:50 PM
02/07/16 04:50 PM
gregsdart Online content OP
gregsdart  Online Content OP
I run through the traps as high as 7800 rpm, and figure it might be worth going to a hollow stem steel valve? I plan on going to an .850 lift combo, and may need an additional .050 length beyond the BBC 5.444 (+.100)valves now in the heads.
Would appreciate anyone's experience with these.
Re: Hollow stem valves? [Re: gregsdart] #2007449
02/07/16 05:08 PM
02/07/16 05:08 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
What size intake valve?
I would do titanium valves
7mm or 5/16
Your springs and lifters will thank you.
Sounds like you need a 5.540ish valve.
Re: Hollow stem valves? [Re: gregsdart] #2007452
02/07/16 05:17 PM
02/07/16 05:17 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
If you think you need hollow stems....... You need titanium.
Re: Hollow stem valves? [Re: fast68plymouth] #2007507
02/07/16 06:50 PM
02/07/16 06:50 PM
SoCal
Brian Hafliger Offline
SoCal
Exactly! Hollow stems are for class racing or hyd. roller stuff...Ti. is for you Greg!
And watch the ex. valve weight too as it's important at that rpm as well.
Brian Hafliger
Re: Hollow stem valves? [Re: fast68plymouth] #2007768
02/08/16 02:40 AM
02/08/16 02:40 AM
Thanks for the input, guys. I don't know if I need hollow stems or Ti valves, but figure I may be on the edge with the steel stuff? 16 Ti valves would put a hurt on what I have budgeted for this season for freshen up. My thinking is, I have a mild exhaust lobe ; 296 @ .050 of duration, only .684 lift with 1.55 rockers, .748 with 1.7 rockers. I am running the 1.55 rockers at the moment. I hope I can get by on that side by carefully setting up the springs, and running enough pressure. At 2.000 I.H. I have 310 lbs on the seat, comp 947 triples. I can run them tighter and gain seat pressure if needed? I have a new set of slicks that will bring the rpm down to about 7600 rpm, which will help. I shift at 7100.
The intakes are what I am more concerned about, 2.300 + .100 long BBC stainless valves. I will be going to 2.050 I. H. and Comp 948 springs, which will be about 370 lbs on the seat. I should be about .085 to coil bind on the intakes, a lot more on the exhaust.
I have read that the hollow valves will add about half the rpm range you can gain with Ti valves, and eight steel hollow stem intakes won't break the bank. I need to freshen the valve job anyway. So that is where all this started, hoping to gain a bit of horsepower, and add a little margin to my rpm range on a budget. Would appreciate opinions on the plan.
Re: Hollow stem valves? [Re: gregsdart] #2007814
02/08/16 08:59 AM
02/08/16 08:59 AM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Does anyone even make a 2.30 hollow stem valve? I believe Ferrea only goes to 2.250. Your options may be limited. S/F....Ken M
Re: Hollow stem valves? [Re: gregsdart] #2007819
02/08/16 09:28 AM
02/08/16 09:28 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I found that shifting mine doesn't make a whole lot of difference between 6900-7200, why not just run it through at 7000-7200? Mine runs 2.25" stainless currently with Comp 996@1.950", just over 300/800,.471" lobe@1.7, .785" after lash. It's apart for freshening. Everything looks nice. Lobes are not beat up at all.
Doug
Re: Hollow stem valves? [Re: dvw] #2007849
02/08/16 11:42 AM
02/08/16 11:42 AM
Ken, I didn't see anything in 2.300 either, but figure someone may make them on request. Doug, I do shift it at 7100 on an rpm switch now, but the trap rpm is where it might get a bit high. My cams that I have run all look very good.
Re: Hollow stem valves? [Re: gregsdart] #2007868
02/08/16 12:14 PM
02/08/16 12:14 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Greg have you tried taking gear out of it and running lower trap rpm? I don't think it really hurts mine, I'm heavier than you. MPH vs ET, 9.02@151, 3350, 4.10, 10.5wx31. Not very aerodynamic either. Titanium is WAY out of my pay grade.
Doug
Re: Hollow stem valves? [Re: gregsdart] #2007921
02/08/16 02:21 PM
02/08/16 02:21 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
IMO you will be WAY better off going to a titanium valve. A lot of weight in a steel valve that size
Re: Hollow stem valves? [Re: gregsdart] #2008067
02/08/16 06:21 PM
02/08/16 06:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont think you would need Ti exhaust valves..
they are lighter than the intakes... sure you could
put them in if you wanted to lighten up everything
and then use different(lighter springs).. my B-1 stuff
was 2.4 Ti intakes with steel exhaust.. I was gonna turn
that to 9000
wave
Re: Hollow stem valves? [Re: MR_P_BODY] #2008122
02/08/16 07:39 PM
02/08/16 07:39 PM
SoCal
SoCal
that to 9000
wave
If your ex. valve is heavier than 125g, you might not like the results! Yes you can use heavier springs, but you will lose a bit of power that way...guess it depends on how much power your willing to lose or pay for.
9000 is a lot of rpm for a steel valve over that weight...
Brian Hafliger
