Which slicks to run??? #2007501
02/07/16 06:46 PM
02/07/16 06:46 PM
Stockholm, Sweden
TomsCharger70 Offline OP
Stockholm, Sweden
I need new tires for my Charger, been running 29" Hoosier QTP.
Ive been looking at the Hoosier 30x9" bias-ply slicks. I cant fit 29x9" Mickey Thompson slicks because they are so wide side-side. Also I run 4.56 gears, so a 28" diam. tire wont work.
The Hoosier bias-ply slicks come in two different compounds, where one is softer (D5), the other firmer (D7), so which of the tires would be better?
My car weighs race ready 3891lbs. Cal-Tracks, AFCO DA chocks front/rear, etc...
I can/will not run a radial tire because the track i run at does not have the grip needed for a radial tire...
Thanks!
/Tom
Re: Which slicks to run??? [Re: TomsCharger70] #2007554
02/07/16 08:38 PM
02/07/16 08:38 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
Take a look at the 9" Phoenix slicks. Jim
Re: Which slicks to run??? [Re: TomsCharger70] #2007566
02/07/16 08:54 PM
02/07/16 08:54 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I run the M/T 29X9 stiff sidewall slick on my car and they hook most anywhere I race.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Which slicks to run??? [Re: TomsCharger70] #2007622
02/07/16 11:06 PM
02/07/16 11:06 PM
Stockholm, Sweden
Stockholm, Sweden
Cant use the Phoenix slicks, the side-side is to wide, just like the M/T slicks!
Thanks!
/Tom
Re: Which slicks to run??? [Re: TomsCharger70] #2007638
02/07/16 11:35 PM
02/07/16 11:35 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
M/T has radial slicks as well. Not sure on the dimension but might look at them if radial is a thought. Sounds like your decision is already made otherwise...
Re: Which slicks to run??? [Re: TomsCharger70] #2007688
02/08/16 12:38 AM
02/08/16 12:38 AM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
Thanks!
/Tom
Is this in a '70 Charger? In my experience you can easily fit a 10.5 x 29 tire in there...do you have wheels with alot of backspace and you're hitting the spring?
Re: Which slicks to run??? [Re: TomsCharger70] #2007700
02/08/16 12:53 AM
02/08/16 12:53 AM
N.W. Indiana
DblOJoe Offline
DblOJoe  Offline
N.W. Indiana
The d05 is really soft and didn't work well for me on a hot greasy track. The d07's worked really well no matter what the prep was.
