Merge collectors. Do they really help? #2007506
02/07/16 06:50 PM
02/07/16 06:50 PM
Charlotte, North Carolina
sgcuda Offline OP
sgcuda  Offline OP
Since I'm still in the rebuilding stages, I have been doing a lot of reading. I am currently running 2 1/8" primary tubes into 3 1/2" collectors. I am going to build up another set of 4" collectors for testing, since the new motor is 500". I have been thinking about trying out some merge collectors. Maybe narrow down to 3" and come back up to 4" or 4 1/2"? Has anyone seen any real improvements over a standard type collector? From what I have read, bottom end torque really increases without sacrificing top end hp.
[image][/image]
Re: Merge collectors. Do they really help? [Re: sgcuda] #2007521
02/07/16 07:26 PM
02/07/16 07:26 PM
AndyF Offline
AndyF  Offline
How far are you from Elston Exhaust? Calvin can answer your question. I'm pretty sure he'll tell you that it isn't as simple as changing the collector.
Re: Merge collectors. Do they really help? [Re: sgcuda] #2007537
02/07/16 07:44 PM
02/07/16 07:44 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Ive tested them on a few motors.
They don't always work....... And they aren't all created equal.
Re: Merge collectors. Do they really help? [Re: AndyF] #2007544
02/07/16 07:59 PM
02/07/16 07:59 PM
sgcuda Offline OP
sgcuda  Offline OP
Never heard of them, but I will find out. Thanks.
[image][/image]
Re: Merge collectors. Do they really help? [Re: fast68plymouth] #2007548
02/07/16 08:05 PM
02/07/16 08:05 PM
sgcuda Offline OP
sgcuda  Offline OP
I have noticed that price varies, along with construction, which I am sure reflects function. The old saying "You get what you pay for" still applies. The cheaper ones have very short tapers back to a straight tube, while the more expensive ones will have a much more gradual, longer cone.
[image][/image]
Re: Merge collectors. Do they really help? [Re: sgcuda] #2007555
02/07/16 08:40 PM
02/07/16 08:40 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I can't say for sure because I changed everything when I built my headers. Plus I went from hooker fenderwell headers.
I used them because edelbrock had them on sale lol
Re: Merge collectors. Do they really help? [Re: FastmOp] #2007605
02/07/16 10:33 PM
02/07/16 10:33 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
The guy that built my header for my new car recommended Dynatech merge collectors so I ordered a set last year with a 10% off coupon. They look very nice.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Merge collectors. Do they really help? [Re: sgcuda] #2007630
02/07/16 11:26 PM
02/07/16 11:26 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
They look very nice
1963 Plymouth Max Wedge
1971 Barracuda
Re: Merge collectors. Do they really help? [Re: ozymaxwedge] #2007645
02/07/16 11:40 PM
02/07/16 11:40 PM
PA.
"Little"John
"Little"John
PA.
Thanks. I can't wait to give them a try.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Merge collectors. Do they really help? [Re: sgcuda] #2007806
02/08/16 05:45 AM
02/08/16 05:45 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
We went from a set of horrible, home hash up 2 1/4 x 4 straight collector to a beautifully made custom set of stainless 2 1/4 with merge collectors and picked up nothing, there was no other changes. Sure looks a lot better under the hood though.
Re: Merge collectors. Do they really help? [Re: Tig] #2007807
02/08/16 05:52 AM
02/08/16 05:52 AM
I think the key to merged collectors working well or not is the pipe timing in relation to the firing order and the placing of the pipes from each other based on the firing order. What little I remember about the theory is you do not want two pipes blowing into each other that are 90 degrees crankshaft firing order away from each, you shold have them side by side so the pulse from the first one helps suck the other out the collector, not blow against each other confusedMaybe not shruggy I'll try and ask my Son tomorrow about what they did and the rules they followed when he made them for Rob Muzzy racing.
Re: Merge collectors. Do they really help? [Re: sgcuda] #2007851
02/08/16 11:45 AM
02/08/16 11:45 AM
an8sec70cuda Offline
If you had a lot of time, plenty of money, and your own dyno...I'm sure you could eventually find a header primary and collector combo that would make a few more horsepower over an off the shelf set.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Merge collectors. Do they really help? [Re: an8sec70cuda] #2007862
02/08/16 12:09 PM
02/08/16 12:09 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
A proper merged collector will add performance , but they are not a one size fits all kind of deal.
Thinking you will get a huge difference will leave you baffled and / or disappointed unless you take all the variables into consideration when building them.
And even then , the difference won't be felt in the seat of the pants.
I could see them in a heads up , every ounce of oomph kind of deal.
Otherwise , it's more for show and tell.
Re: Merge collectors. Do they really help? [Re: sgcuda] #2007886
02/08/16 12:57 PM
02/08/16 12:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Merge collectors have to be built to YOUR engine..
they are designed for a certain rpm and if you move
too far from that rpm they dont add anything.. so if
you feel you can buy a off the shelf merge and expect
to to add performance your kidding yourself... a straight
collector will do more if you make the collector 16"-18"
long... I made a few merge collectors at work to test on
the dyno... each one hurt power at most points(until it
crossed the RPM where it worked).. think a expansion
chamber on a 2 stroke.. they work on a certain engine for
a certain rpm range... I built a set of chambers for my
snowmobile.. it KILLED the top end but it turned it into
a tree puller on low end.. because I didnt have
the inlet cone and exit cone the right diameter
and length
wave
Re: Merge collectors. Do they really help? [Re: sgcuda] #2007899
02/08/16 01:22 PM
02/08/16 01:22 PM
So. Burlington, Vt.
So. Burlington, Vt.
There are very few "silver bullets" in the power building hobby.
The biggies are nitrous and boost of course.
Re: Merge collectors. Do they really help? [Re: sgcuda] #2007953
02/08/16 03:26 PM
02/08/16 03:26 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
My buddy put some merge collectors on his stocker. He said it seemed to pick up .01 or so in the 60', but he said the change was so small he could not prove it one way or the other.
Re: Merge collectors. Do they really help? [Re: fast68plymouth] #2007964
02/08/16 03:44 PM
02/08/16 03:44 PM
AndyF Offline
AndyF  Offline
I've read most of what Calvin has posted on 4-2-1 headers and merger collectors and I think it boils down to building an effective extractor type header system which then allows the engine builder to use a smaller exhaust valve which in turn allows a larger intake valve. So not a silver bullet at all! But the NASCAR guys have used it to pick up some power and I'm pretty sure those engines are tuned now to a point where a standard off the shelf type of header would kill off a bunch of power.
The big trick seems to be cutting the primary length way down to improve high speed performance. Then the merge and choke are used to make it work on the bottom end. This is why just welding a merge collector onto a standard set of pipes doesn't do much. It doesn't start to work until the pipe length is correct which takes some math to figure out.
Re: Merge collectors. Do they really help? [Re: sgcuda] #2007972
02/08/16 04:10 PM
02/08/16 04:10 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
For my Dodge these make the most power Flowmaster’s retrofit-style 4-2-1 Scavenger Series. I built several sets of headers for the car, used standard 4 into one and merge type collectors. 512 wedge NSS type car. There is a program called pipemax that allows you to size your headers correctly, and give you lengths for step headers as well. http://www.maxracesoftware.com/
It also has a pretty good engine output estimator in the program as well.
Re: Merge collectors. Do they really help? [Re: jwb123] #2007976
02/08/16 04:14 PM
02/08/16 04:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've used that program for YEARS
wave
