Brake Pad hanging up #2006910
02/06/16 07:34 PM
02/06/16 07:34 PM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
Subject matter is a 2007250 4WD CTD.
Just got back from a 500 mile run and noticed I have an excessive amout of brake dust on the driver side front. My concern is the pads are hanging up or the caliper piston is not disengaging. Anyone else have a problem with this? I'll be taking it to the shop on Monday to have a look.
Abe Lincoln
Re: Brake Pad hanging up [Re: dart4forte] #2006974
02/06/16 09:22 PM
02/06/16 09:22 PM
London Ontario Canada Eh
Dono Offline
Dono  Offline
Yes over and over. My 06 1500 just had the front wheel bearing done and rotor because it got so hot the last time it hung, it warped the rotor. It took about four months before the wheel bearing went but I am expecting that was the cause of the premature failure.
Had one hang on the rear as well and it took out the rear axle seal on the passenger side.
Both times the brake caliper was warrantied but none of the other damage was.
I have gotten in a habit now spring and fall to pull them off put some anti seize on the two stainless rods.
Pop it off run some sand paper in them and on the rods then silver anti seize and your off.
Cheers Don.
Re: Brake Pad hanging up [Re: dart4forte] #2007242
02/07/16 10:14 AM
02/07/16 10:14 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Antiseize on brake parts is evil. It WILL make the rubber seals and bushings for the pins swell and makes things stick worse.
Use caliper lube (siicone based)
Backyard mechanics that did antiseize have paid me well to fix their problems.
Angry white pureblood male
Re: Brake Pad hanging up [Re: dart4forte] #2007844
02/08/16 11:32 AM
02/08/16 11:32 AM
Dono Offline
Dono  Offline
What rubber seals? The boots on the pins?
Re: Brake Pad hanging up [Re: Dono] #2007933
02/08/16 03:03 PM
02/08/16 03:03 PM
northeast ohio
hulmule Offline
hulmule  Offline
northeast ohio
I wouldn't use sand paper on the pins. Cleaners, fine steel wool etc. don't want any scratches on them. use a good caliber lube. I always clean the slides good. if u do your own work, a lot of new pads new to be ground down so they slide free when installed or they hang up.hope u get fixed
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: Brake Pad hanging up [Re: dart4forte] #2007941
02/08/16 03:15 PM
02/08/16 03:15 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Yes the boots on the pins, many vehicles have small bushings for the pins that will swell and stick the pins.
Mule is right that sometimes pads need the backing clearanced. Also rust buildup on the support brackets need cleaned off.
Re: Brake Pad hanging up [Re: dart4forte] #2008133
02/08/16 07:48 PM
02/08/16 07:48 PM
Dono Offline
Dono  Offline
I have had really good luck since I started using anti-seize on the pins. I have had more problems with the stock lube then a light coat of anti-seize.
List of parts because of stock lube.
I after market vented rotor HD, one front wheel bearing, Set of pads front and back, rear brake rotor aftermarket vented HD, and rear axle seal.
The aftermarket vented rotors are built so well they should not warp but you run long distances with a hung caliper its not long dinking parts.
To each their own. I am not in the business of changing parts all the time.
Re: Brake Pad hanging up [Re: dart4forte] #2008253
02/08/16 11:09 PM
02/08/16 11:09 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Neither am I.
Stock lube is too sparse IMHO.
Corrosion is a big deal in my area. Not yet set and salt, but the brine they spray is plain evil to anything metal. Keeping the brine out of moving parts is paramount to keeping things working right.
With properly lubed and cleaned slides my pplow truck hasn't needed brake attention in 3 years.
