3 clutches or 4 clutches in front clutch pack of 727?
#2006671
02/06/16 01:05 PM
02/06/16 01:05 PM
Posts: 2,403 WASHINGTON, PA
11secaarcuda
WASHINGTON, PA
Which is better: 3 of the thicker clutch plates or put 4 of the thinner clutch plates and steels if they will fit and still give the necessary clearance?
67 Dart GT 340 4 speed 70 AAR Cuda 408 6 barrel 96 Indy Ram original owner 2011 Hemi Durango
Re: 3 clutches or 4 clutches in front clutch pack of 727?
[Re: 11secaarcuda]
#2006780
02/06/16 03:19 PM
02/06/16 03:19 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
The discs don't wear away unless they are slipping, more friction surface equals more holding power. I have pulled discs out of 50k mile diesel trans that you could still seeing the ink letters on the discs clearly.
I have 6 clutches in a 4 clutch drum in my Diesel Ram .
[Re: 11secaarcuda]
#2007565
02/07/16 08:54 PM
02/07/16 08:54 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Converting a 3-disc drum to 4-disc is a simple lathe job (if you have access), the common 1/8" wide cutoff tool is perfect for cutting a new groove.
