slant 6 convert from 3 speed to 4 speed?
#2006309
02/05/16 09:09 PM
02/05/16 09:09 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
i have a 65 dodge coronet 3 on the tree. i want to put a 4 on the floor. what bellhousing do i need and would an a body work?
Hell Hath No Fury Like Mine
Re: slant 6 convert from 3 speed to 4 speed?
[Re: sixpacksteve]
#2006318
02/05/16 09:37 PM
02/05/16 09:37 PM
Posts: 20,205 Park Forest, IL
slantzilla
Park Forest, IL
You will need the bellhousing with the right size opening for the bearing retainer on your trans. The later the trans, the larger the retainer got.
[Re: cudaman1969]
#2007133
02/07/16 01:19 AM
02/07/16 01:19 AM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
Only /6 bell housings will work. Not sure if they had both patterns ( 3&4 speed ) I'll check mine tomorrow. Got 64, 70 and 72. Do you have a trans yet? If so what year? No they do not as far as I know. There were slant sixes made with 4 speeds but the bell housings are a bit tough to find.
[Re: sixpacksteve]
#2007354
02/07/16 02:20 PM
02/07/16 02:20 PM
slantzilla
Park Forest, IL
The '70's bellhousings had multiple patterns, but the big thing is the hole for the bearing retainer. If you find a housing from an OD trans you can use a spacer ring for the smaller retainers.
The early 4 speed housings are tough to find.
[Re: sixpacksteve]
#2008337
02/09/16 12:54 AM
02/09/16 12:54 AM
slantzilla
Park Forest, IL
Probably the easiest to find will be a '73 and up A/F body OD bellhousing. I have one laying around.
