Lower control arm coating? #2006298
02/05/16 07:48 PM
02/05/16 07:48 PM
South Dakota
hotairballoonpilot Offline OP
South Dakota
I know they were originally coated and dipped. Has anyone ever painted them close to the yellow/goldish color? Want the look but thinking drive ability too.
Contact Me about AMD Prices
Re: Lower control arm coating? [Re: hotairballoonpilot] #2006300
02/05/16 07:51 PM
02/05/16 07:51 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
http://www.restorick.com/products.asp?id=11
Re: Lower control arm coating? [Re: flypaper] #2006323
02/05/16 08:47 PM
02/05/16 08:47 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
I used Resto Rick's Quasimoline Paint recommended above, here's a pic before I put the arms on the car.
jess
Yeah, it's hopped up to over 160...
Re: Lower control arm coating? [Re: jt4406] #2006342
02/05/16 09:39 PM
02/05/16 09:39 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
I used Krylon battery protector and it worked just great!
http://www.ebay.com/itm/Krylon-1307-Battery-Protector-11-oz-Aerosol-New-/371249746007?hash=item5670359057:g:BQcAAOSwBahUz-gi
Admiration For Multiple Carburetor Vehicles...
Re: Lower control arm coating? [Re: hotairballoonpilot] #2006375
02/05/16 10:27 PM
02/05/16 10:27 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
I had my control arms powder coated a natural steel color and then treated them with the Krylon battery protector. I'm happy with how they turned out. I can't comment on durability until my car is assembled and on the road.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: Lower control arm coating? [Re: hotairballoonpilot] #2006393
02/05/16 10:50 PM
02/05/16 10:50 PM
wellington ohio
68-scatpack-rt Offline
In thin ice
In thin ice
wellington ohio
Used the resto Rick quasimoline and it came out great.
unions....the folks who brought you the weekend!
Re: Lower control arm coating? [Re: hotairballoonpilot] #2006398
02/05/16 10:54 PM
02/05/16 10:54 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Cosmoline works great (and it's original!). First pic is my originals being dipped, second shot is an NOS example
Re: Lower control arm coating? [Re: hotairballoonpilot] #2006506
02/06/16 01:48 AM
02/06/16 01:48 AM
South Dakota
South Dakota
Thanks guys!!! Think I'll do resto ricks
Re: Lower control arm coating? [Re: hotairballoonpilot] #2006731
02/06/16 01:06 PM
02/06/16 01:06 PM
Pa.
3
340cpe Offline
340cpe  Offline
Pa.
Scott is it true that some 71 and up b-bodies were painted black instead? I have a couple of those cars and there is no evidence of cosmoline coating. They are Lynch road cars and have black LCA,s
Re: Lower control arm coating? [Re: hotairballoonpilot] #2006753
02/06/16 01:47 PM
02/06/16 01:47 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Cosmoline wore off quite quickly, I doubt you'd find any on most examples, normally you just see bare steel and rust. What you can sometimes see is a line near the ends where the metal is in better or worse condition indicating that some areas had protection for a while and others did not. *Also, don't mistake any inspection paint blotches you see as part of an overall coverage, the torsion bar adjusters are commonly blotched with paint, some of it was black.
Chrysler had multiple vendors for most parts, not all vendors did things the same way in meeting the specs on the print, one might have used Cosmoline while another used paint to offer the required temporary rust protection. Then there were different vendors for different plants (and Lynch Road and Los Angeles are known for having some unique parts sources) There could have been a change mandated by Chrysler to paint them black in later years.
That said, MANY replacement parts were painted black, likely because it offered better rust protection and made for an easier to handle part.
All of my NOS examples have been Cosmolined, and most had part label tags dated in the early to mid 1970's, after 1971 production ended.
So yes, it's possible yours were black. When faced with (any) detail that is out of the accepted "norm" it's always a good idea to document as many unmolested examples as possible to support your case.
Re: Lower control arm coating? [Re: ScottSmith_Harms] #2006790
02/06/16 02:33 PM
02/06/16 02:33 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
My 72's were not Black from factory. Any Black you see in the picture was dirt/grease that wasn't washed off yet.
Ron
Re: Lower control arm coating? [Re: RJS] #2006792
02/06/16 02:37 PM
02/06/16 02:37 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Resto Rick's spray Cosmoline.
Ron
Re: Lower control arm coating? [Re: hotairballoonpilot] #2006826
02/06/16 03:51 PM
02/06/16 03:51 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Maybe it`s the pics but Resto Rick`s stuff looks a little to orange? All the NOS ones I have seen were more greenish/darker in color.
Time just gets away from us
I`m here until I`m not
Re: Lower control arm coating? [Re: 340cpe] #2006833
02/06/16 04:19 PM
02/06/16 04:19 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
A.O. Smith was the original vendor to supply Chrysler with the lower control arms, after the arms were constructed, they were place on a overhead conveyor hook line that then took them into a large Cosmoline tank, the LCA's were suspended by the ball joint socket casting hole in the LCA, Chryslers specs were not to sumbmerge the part completely, as wax in the ball joint socket prevented proper speedy assembly on the line, plus the line worker had ZERO time to clean out the socket, the Cosmoline dip line will vary as the level in the tanks at A.O Smith would vary daily due to the consumption/volume of product traveling thru them, when production quotas were met, the remaining stock of LCA's were them completely submerged in a tank of black paint wash to completely seal the part from rusting, these black LCA's were intended for dealer/service stock as shelf life would/could be a matter of years, and as a service replacement the installer had the time to remove any paint from a ball joint socket, or any other assembly end of the LCA,...there could be the chance some may have made it to the assy line because of a vendor shortage?, a misdirected order? any host of reasons.
Mike
Re: Lower control arm coating? [Re: hotairballoonpilot] #2006840
02/06/16 04:33 PM
02/06/16 04:33 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
IMHO Cosmoline is the only way to get an authentic finish, I only do my restorations of LCA's in Cosmoline, and while it seems it takes forever for them to completely "dry", they are something best done very early in the resto so they can hang around and cure, that being said I have some LCA's that I did 20 years ago with tens of thousands of street driven dry/wet miles on them that still look freshly Cosmolined...the trick is not to overdo the coating whether you spray or dip it in Cosmoline
Mike
Re: Lower control arm coating? [Re: hotairballoonpilot] #2006892
02/06/16 06:10 PM
02/06/16 06:10 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
I bought new upper/lower control arms around 1985 & they where all black I think possibly one was red oxide,they did get respray bombed black back then.
Re: Lower control arm coating? [Re: 71GTX471] #2006909
02/06/16 06:34 PM
02/06/16 06:34 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Got 20+ years on LCA's that were blasted, primed, and sprayed in black satin urethrathane...
Holding-up real well...
Can't see going 'cosmo' for a driver...
Re: Lower control arm coating? [Re: RSNOMO] #2007103
02/06/16 11:42 PM
02/06/16 11:42 PM
Long Island, NY
70plymA34 Offline
70plymA34  Offline
Long Island, NY
what is the drying time for cosmoline. are we talking weeks or months here?
Super Commando
Re: Lower control arm coating? [Re: hotairballoonpilot] #2007116
02/07/16 12:03 AM
02/07/16 12:03 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
It varies with temperature and humidity, after several days to a couple weeks it usually hardens to a fairly tough waxy texture, it continues to harden over the next couple months as the solvents evaporate from it.
Re: Lower control arm coating? [Re: mopars4ever] #2007211
02/07/16 02:56 AM
02/07/16 02:56 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Isn't Resto Rick's item actually real cosmoline served up in a spray can so you don't have buy 5 gallons to dip it? According to his web site,
"Aerosol spray can of Cosmoline rust inhibitor coating as used on Mopar lower control arms. Also an excellent corrosion inhibitor for coating inner panels such as door skins. Price: $10.00"
I bought a can but haven't used it yet.
Re: Lower control arm coating? [Re: hotairballoonpilot] #2007232
02/07/16 06:56 AM
02/07/16 06:56 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
So, Resto Rick sells both aerosol cosmoline and a paint imitation. Note discussion about coloring.
"Quasimoline Paint
Urethane paint formulated to closely mimic the original cosmoline finish used on Mopar lower control arms. This is an ideal product for those wanting a durable finish that can be wiped clean and not hold dirt like the real thing. Dries to a satin gloss. Darkness & coloring will vary with number of coats applied and color of control arm. Thin with a urethane reducer, no hardener required. Sold in a half pint can for use with a spray gun. One can will easily do two sets of control arms, depending on application thickness. Can also be used to accentuate the coloring of some cast iron parts. $24"
Re: Lower control arm coating? [Re: hotairballoonpilot] #2007662
02/07/16 11:07 PM
02/07/16 11:07 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
I used Rick's Quasimoline and liked how it came out. After getting the coverage I wanted, I over-reduced it and hung a couple of runs on the pieces (hanging vertically of course) for good measure.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: Lower control arm coating? [Re: hotairballoonpilot] #2008104
02/08/16 06:15 PM
02/08/16 06:15 PM
MO
cdp Offline
cdp  Offline
MO
http://www.schafco.com/cosmoline.asp
couple of good products i've used.
Rust veto, for protecting metal from rusting, and weather shed, cosmoline in a can.
Re: Lower control arm coating? [Re: hotairballoonpilot] #2009324
02/10/16 03:43 PM
02/10/16 03:43 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
On my 70 sport satellite, I cleaned up the lca and then used RPM on them. Let them dry real good, then used real cosmoline on them . . . So even if cosmoline comes off, then the RPM can protect . .
Re: Lower control arm coating? [Re: hotairballoonpilot] #2009906
02/11/16 03:03 PM
02/11/16 03:03 PM
South Dakota
South Dakota
I got resto ricks spray can stuff. seemed to work out nice. rough taped a line in them and sprayed hanging up so it has drips and runs in it. Now if it will dry!
Re: Lower control arm coating? [Re: Stewpar] #2012050
02/14/16 09:19 PM
02/14/16 09:19 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
You Will be happy ..
http://a12mopar.com/yabb/YaBB.pl?num=1232666360
Re: Lower control arm coating? [Re: mopars4ever] #2060023
04/22/16 10:00 PM
04/22/16 10:00 PM
WI
RestoRick Offline
RestoRick  Offline
WI
It's a match to the original coating. Aside from lighting & photo differences, the number of coats, viscosity of the paint & color of the metal or "metal-look" coating under it will all effect the final color.
Most people tend to put on too much.
Re: Lower control arm coating? [Re: hotairballoonpilot] #2061643
04/25/16 07:54 PM
04/25/16 07:54 PM
md
mopars4ever Offline
mopars4ever  Offline
md
NOS upper arm
Re: Lower control arm coating? [Re: hotairballoonpilot] #2061650
04/25/16 08:11 PM
04/25/16 08:11 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Be careful when using NOS parts for correct production line details, they often had different finishes as compared to production.
Re: Lower control arm coating? [Re: hotairballoonpilot] #2111219
07/16/16 04:12 PM
07/16/16 04:12 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
This is an example of the krlyon battery spray.....
if sprayed heavier to make runs you can get a darker/redish end result
Re: Lower control arm coating? [Re: hotairballoonpilot] #2112856
07/18/16 09:54 PM
07/18/16 09:54 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Looks good I'd be happy with that...
Re: Lower control arm coating? [Re: RJS] #2754882
03/23/20 07:51 AM
03/23/20 07:51 AM
New Jersey
Vinny P Offline
Vinny P  Offline
New Jersey
Hi Ron,
I have a question about the blue and red paint on the LCA pivoting height adjusters tips. The info would be nice additional info to the pictures posted. Or, just give me a call.
Vinny
Superbird B5 4 speed console black buckets
A12 Super Bee Bahama Yellow 4 speed black bench
Re: Lower control arm coating? [Re: Vinny P] #2755978
03/25/20 05:27 PM
03/25/20 05:27 PM
West Central Wi.
1969 HEMI R-T Offline
West Central Wi.
here are mine. I bought the paint. from Resto Rick. it works very well. I like the likeness to the cosmoiline, and it's more durable. I may try cosmoiline next time., but want to drive this car.
HEMI,S ARE FOREVER!!!
