Dana 60 to Dana 70 conversion possible? #2006237
02/05/16 07:28 PM
02/05/16 07:28 PM
Charlotte, North Carolina
sgcuda Offline OP
sgcuda  Offline OP
So, a local shop gave me a Ford Dana 70 floater truck rear end for helping them out from time to time. It has 4.10 gears and 3.5 axle tubes. Axle spline count is 32. Does anyone make a spool for a D70 with 35 splines so I could reuse my Moser axle shafts, and are there 3.5" axle flanges available for the passenger car bolt patterns. I am guessing I wouldn't have to worry about pro or street gears with a 10.5" ring gear.
[image][/image]
Re: Dana 60 to Dana 70 conversion possible? [Re: sgcuda] #2006254
02/05/16 07:45 PM
02/05/16 07:45 PM
Stinnett, Tx
rumblebee4232 Offline
Stinnett, Tx
I have looked before for one but was unable to locate one, that has been a while ago so things may have changed..
Re: Dana 60 to Dana 70 conversion possible? [Re: sgcuda] #2006259
02/05/16 07:56 PM
02/05/16 07:56 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
east coast gear supply lists a dana 70 spool, but the description says its a dana 80 spool with the conversion parts to make it work in a 70. Takes the same 70 ring gear and 35 spline axles
Re: Dana 60 to Dana 70 conversion possible? [Re: sgcuda] #2006340
02/05/16 10:36 PM
02/05/16 10:36 PM
Canada
onig Offline
onig  Offline
Canada
Guys have put 70 gears in a 60 housing (if that is what you are asking). Some grinding is required for the crown gear to fit and possibly different side carrier bearings will be needed. If you google the net you should find how to do it. I came across it a couple of times doing a search.
69 Dart
Re: Dana 60 to Dana 70 conversion possible? [Re: sgcuda] #2006350
02/05/16 10:50 PM
02/05/16 10:50 PM
sgcuda Offline OP
sgcuda  Offline OP
Just trying to make the 70 work on its own. Already have a set of 35 spline axles out of my 60.
[image][/image]
Re: Dana 60 to Dana 70 conversion possible? [Re: sgcuda] #2006501
02/06/16 02:33 AM
02/06/16 02:33 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I'm sure Moser would make a custom spool if you need one.
I would call them and ask a tech guy, there pretty good
Re: Dana 60 to Dana 70 conversion possible? [Re: sgcuda] #2006583
02/06/16 09:34 AM
02/06/16 09:34 AM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
I personally think the weight to strength difference isn't worth it.
What does it weigh? 300lbs
Are you breaking 60's?
I dont imagine a lot of gear selection
Re: Dana 60 to Dana 70 conversion possible? [Re: The Shadow] #2006590
02/06/16 10:07 AM
02/06/16 10:07 AM
sgcuda Offline OP
sgcuda  Offline OP
The ring gear diameter is 10.5" vs a D60 that is 9.75". Strength is much higher in a 70 than a 60. Haven't weighed both housings yet, but I don't see the 70 being that much of an overwhelming increase. Yeah, it was real heavy, until I pulled the hubs, rotors, axles out. I will weigh it after I cut it to proper length, for comparison. I'm not breaking anything, but I need to replace my existing housing and am checking different options. Gear ratio's are available from 4.10 up to 7.17. I don't think a "Pro" style gear will be necessary.
[image][/image]
Re: Dana 60 to Dana 70 conversion possible? [Re: sgcuda] #2006632
02/06/16 12:09 PM
02/06/16 12:09 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I'd sell it to a truck guy and buy the Dana 60 parts I need.
Re: Dana 60 to Dana 70 conversion possible? [Re: sgcuda] #2006865
02/06/16 06:20 PM
02/06/16 06:20 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
I agree...........a 60 is heavy enough, why put a "tank" differential in a race car, or any car for that matter
Re: Dana 60 to Dana 70 conversion possible? [Re: sgcuda] #2006876
02/06/16 06:49 PM
02/06/16 06:49 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Or do the Jana 76 conversion if you're after the strength increase. It's where you put the 70 ring and pinion in a 60 housing
Re: Dana 60 to Dana 70 conversion possible? [Re: sgcuda] #2007025
02/06/16 10:53 PM
02/06/16 10:53 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
If you can put a 70 gear in a 60 can't you put a 60 gear in a 70? That being said junkyard 60s are pretty easy to come by. I personally wouldn't bother with the extra weight and 3 1/2" tubes.
Doug
Re: Dana 60 to Dana 70 conversion possible? [Re: dvw] #2007855
02/08/16 11:53 AM
02/08/16 11:53 AM
an8sec70cuda Offline
Doug
iagree iagree iagree
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Dana 60 to Dana 70 conversion possible? [Re: sgcuda] #2007923
02/08/16 02:26 PM
02/08/16 02:26 PM
Cab_Burge Online work
Cab_Burge  Online Work
I ended up owning the Dana 70 Mopar made and gave to John Deianna(SP?) that was for his old Duster modified production car, that rascal was really heavy with all the stock brakes on it. It did have a posi in it, not a spool so there is some weight there but there is no way I would do that agian. He got it due to using destroke small C.I. 340 motors that they RPM the crap out of back then, early to mid 1970, he had rear gear ratio from 5.86 to 7.50 that Mopar sent him shock shruggy there are two different ring gear offsets in the stock Dana 70 depending on year and application so be careful on selecting a part number on gears for the housing you get, if you decide to use one work
Re: Dana 60 to Dana 70 conversion possible? [Re: sgcuda] #2008009
02/08/16 05:00 PM
02/08/16 05:00 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Why do you need to replace your Dana 60 housing?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Dana 60 to Dana 70 conversion possible? [Re: 1967dartgt] #2008214
02/08/16 10:27 PM
02/08/16 10:27 PM
sgcuda Offline OP
sgcuda  Offline OP
Changing ladder bars and brackets. Too much hardware on old housing to remove (ladder bar brackets, shock brackets, wheelie bar brackets). New brackets are a full wrap over the axle tubes, like a four link bracket. Tubes are already bowed, bearing ends have been offset welded to compensate. Car is going to be a lot faster, so I would feel better having a solid foundation to start with.
[image][/image]
Re: Dana 60 to Dana 70 conversion possible? [Re: sgcuda] #2008394
02/09/16 02:47 AM
02/09/16 02:47 AM
Boise Idaho
65coronet500 Online penguin-006
65coronet500  Online Penguin-006
Boise Idaho
To The best of my Knowledge most companies that make 4 link or ladder bar brackets usually only make up to 3 1/8 tube radius or smaller so alot of grinding for very little advantage .
To Be frank i have done rearends for 25 years and have honestly seen more broken Dana 70s than 60s in the pickups they came in originally!
Usually the reason is that the inner pinion race spins in the housing and allows the pinion gear to deflect till they break
I Would just use a 60 and live a happy life without complications of the 70 Good Luck Matt
All steel 3800 lbs with me in it 65 Coronet 451 CID Indy 440-1 heads by Dwayne Porter racing heads .
..... 10.31 @ 129.4 mph 1.40 60 ft ALL MOTOR!!!!
Re: Dana 60 to Dana 70 conversion possible? [Re: WO23Coronet] #2008405
02/09/16 03:28 AM
02/09/16 03:28 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
use the 70 as is, its only about 10# more than a 60 if the tubes are 3.5" the same if the tubes are the same size. I did the 76 conversion, it was a fun project but I should have stuck with a plain 70...Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Dana 60 to Dana 70 conversion possible? [Re: sgcuda] #2008459
02/09/16 11:32 AM
02/09/16 11:32 AM
If the housing and tubes are flexing bad enough that you need a new one, you should be putting a 9" Ford under the car. At the very least use a backbraced factory housing, but you should really look into a fab 9 housing.
CHIP
Re: Dana 60 to Dana 70 conversion possible? [Re: sgcuda] #2008739
02/09/16 07:29 PM
02/09/16 07:29 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
I asked on here a couple years ago...I had a dana 70. And I had ask right here in this four months. If I could put dana 60 parts into a dana 70 housing. And 2as told no. So I pitched it
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
