Re: 1969 RR Brakes!
[Re: HotRodRailroader]
#2005865
02/05/16 01:08 AM
02/05/16 01:08 AM
moparpollack
Lil Herman
Lil Herman
85086
Think of it like a coke bottle, it will always move to the side thats turning less or the side that is braking.
Re: 1969 RR Brakes!
#2005866
02/05/16 01:08 AM
02/05/16 01:08 AM
RapidRobert
it pulling to the right means the DR side ain't doing its share of the load (for whatever reason). Then when you limp it home what happens? A self adjuster might be on backwards but if it straightens out till the next time then it ain't that & I'd open up the DR side & good visual for starters
Re: 1969 RR Brakes!
[Re: RapidRobert]
#2005867
02/05/16 01:10 AM
02/05/16 01:10 AM
moparpollack
Lil Herman
Lil Herman
85086
Re: 1969 RR Brakes!
#2005893
02/05/16 01:52 AM
02/05/16 01:52 AM
RapidRobert
Manual or power? & it is all good till the next time right? You might jack up the front & spin the front wheels by hand forward & work the pedal (grab a helper) till it acts up again then see if anything jumps out at you (& I am assuming the prob is in the dr front (as opposed to dr rear) but it might not be, then open up the dr front while it is up in the air
Re: 1969 RR Brakes!
#2005973
02/05/16 09:05 AM
02/05/16 09:05 AM
Posts: 5,898 ohio
ruderunner
ohio
Crack the rf bleeder immediately after a stop, I bet fluid squirts out. Probably a bad hose holding the rf on just a bit.
Also check the temp of the drums when this happens, a dru that's warmerthan the rest will indicate a problem.
Angry white pureblood male
