Page 1 of 4 1 2 3 4
Cam choice for 505 to run 10.50's #2005724
02/04/16 10:30 PM
02/04/16 10:30 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Motor will be a 4.25 stroke 0.030 Source kit. CNC Source heads cut 76cc , around 11:1 comp,stock port size . Victor or M1 single plane (have both)with Prosystems HP1000 . Do have a dual quad Modman and 1050 dom i could run with adaptor . 5000 stall , 4.1 gears , 28" radial slick . 68 Satellite 3660lbs with me .
Narrowed to 3 choices :
Comp cam #23-634-5 , 305/320 advertised 279/287@050 , 650/630 lift , 110 lobe seperation
Howards #720.21208 , 302/308 , 274/280 , 643/659 lift , 108 lobe seperation
Lunati #30230918 , 308/316 , 279/283 , 617/632 lift , 106 lobe seperation
Car is bracket raced , plus is my daily driver .
Anyone run these ? . Or are they too somilar to worry ? Is nitriding the cam a good idea ? I will use Howards edm lifters .
Any imput appreciated .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Cam choice for 505 to run 10.50's [Re: tex013] #2005728
02/04/16 10:42 PM
02/04/16 10:42 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Top one`s too big for that comp and the others MAY be cos I`m at 276-281 @ .050 at 12.1.1.............
Re: Cam choice for 505 to run 10.50's [Re: tex013] #2005745
02/04/16 10:57 PM
02/04/16 10:57 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
That Comp is in my brother's Edelbrock Rpm headed 493, 11.4 to 1. Replaced a 300/.639 Howards, and solved some of the detonation issues he was having while driving on the street with 91 octane in the tank. He really likes it on the street.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Cam choice for 505 to run 10.50's [Re: MoparBilly] #2005753
02/04/16 11:05 PM
02/04/16 11:05 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Aside from bleeding off pressure, how was the torque down low and mid........?
Re: Cam choice for 505 to run 10.50's [Re: tex013] #2005768
02/04/16 11:20 PM
02/04/16 11:20 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
About the same as the Howards. We hurt the launch with a tighter converter, but the mph was the same, it's far from sorted out, Weiand tunnel ram with 750's. 11.04-121, 3850lbs, and less aero than a 4X8 sheet of plywood.
Re: Cam choice for 505 to run 10.50's [Re: MoparBilly] #2005787
02/04/16 11:35 PM
02/04/16 11:35 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
NORMALLY you`d think the relatively low comp wouldn`t favor that much duration and my car falls in that same category, but again, more "myths" debugged...........I know they can run strong this way but I also know efficiency CAN become less than desireable unless you make up for it w/converter and gears and in some case rpm. thumbs
Re: Cam choice for 505 to run 10.50's [Re: tex013] #2005793
02/04/16 11:41 PM
02/04/16 11:41 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Dom ,
don't you run 470ci and a roller ? sorry if I am wrong .
my understanding is to go 2-3 sizes bigger over your 440ci choice when going stroker . I have 293adv,258@050 cam in current motor .
Billy ,
I did see your input in the other threads . Yes I also run 98 pump gas . I am in the 120/122mph range now . but a little inconsistent et wise .
I am hoping for around 615/625 flywheel HP
I should hope to not shift above 6500 , I shift at 6000 now
Tex
New best MPH 130.32
Re: Cam choice for 505 to run 10.50's [Re: tex013] #2005832
02/05/16 12:34 AM
02/05/16 12:34 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Dwayne Porter nitrided my solid flat tappet for me and I would say its a good idea. I also run the EDM lifters. My solid flat tappet is 264 and 270 @ .050 with .585 and .592 lift and a 110 LSA. And my eng is 10.6 comp as it runs fine on 92 pump. Ron
Re: Cam choice for 505 to run 10.50's [Re: 383man] #2005841
02/05/16 12:44 AM
02/05/16 12:44 AM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
I agree w/Ron regarding nitrating. I also went that route and used the Comp Cams EDM lifters. Just good insurance.
Ok
Re: Cam choice for 505 to run 10.50's [Re: tex013] #2005842
02/05/16 12:47 AM
02/05/16 12:47 AM
Cleburne,Texas
scrapmetal Offline
scrapmetal  Offline
Cleburne,Texas
Not enough head for those cams.Saying it in a nice way not to hurt anyone feelings.
Re: Cam choice for 505 to run 10.50's [Re: scrapmetal] #2005862
02/05/16 01:06 AM
02/05/16 01:06 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Scrap...the problem is not enough head for the cubic inches, hence the need for that much duration. Can't wait to try that Comp grind with some nitrous...
Re: Cam choice for 505 to run 10.50's [Re: tex013] #2005880
02/05/16 01:32 AM
02/05/16 01:32 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Originally Posted By tex013
Dom ,
Billy ,
Tex
Yes sir .680-.660 and I do like to step up the dur. but I have 12.1.1 and will go to 13.1.1 next time to better utilize whats there.......
Re: Cam choice for 505 to run 10.50's [Re: tex013] #2005881
02/05/16 01:32 AM
02/05/16 01:32 AM
Cleburne,Texas
scrapmetal Offline
scrapmetal  Offline
Cleburne,Texas
I had heads that flowed 375 @700 511 cid 3100lb car on alky .714 lift 272 278 @50 run 8.70.maybe AndyF will chime in.He's up on all that stuff
Re: Cam choice for 505 to run 10.50's [Re: tex013] #2005882
02/05/16 01:34 AM
02/05/16 01:34 AM
If those are the only choices I would run the Howards cam and install it at 102 to 105 intake lobe center thumbs twocents With that weight and pump gas the motor needs to make all the power it can in the first hundred feet to get it to E.T. like you want twocents work
Re: Cam choice for 505 to run 10.50's [Re: tex013] #2005888
02/05/16 01:42 AM
02/05/16 01:42 AM
USA
B3RE Offline
B3RE  Offline
USA
Run the Lunati if you have to pick from one of those three. The tight LSA and big duration will hurt the low end, but you have a 5000 converter and 505 ci. It will also come on like a freight train in the mid range and fall off early because you have a limited cylinder head and 505 ci. And finally, it doesn't matter if it falls off early because you have 4.10 gears and 505 ci. You also want to drive it daily, so you might as well make better mid range peak power where you can use it, than better average power where you can't.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: Cam choice for 505 to run 10.50's [Re: 383man] #2005951
02/05/16 05:57 AM
02/05/16 05:57 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
You know i love your car Ron . I will try to call Dwayne next week for his recommendation .
Thanks for all input , a lot to consider .
To clarify , these are flat tappet not roller cams. Sorry if this wasnt clear .
Tex
New best MPH 130.32
Re: Cam choice for 505 to run 10.50's [Re: scrapmetal] #2005999
02/05/16 10:58 AM
02/05/16 10:58 AM
Iceland
BadMoonRacer Offline
Iceland
I tend to agree with thisview, especially if the heads are stock. Anything above .600 lift will not be the best choice.
Ragnar
66 Charger, 451, .582" lift, 11" conv. 4.10:1. 4118 lbs 11.75@117 mph on regular Firestone Firehawk radials.
Icelandic Champion in MC 2007, 2008, 2009 and 2022.
Re: Cam choice for 505 to run 10.50's [Re: BadMoonRacer] #2006039
02/05/16 01:10 PM
02/05/16 01:10 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I agree to a point about peak head flow being the limit that`s why I go bigger in lift and duration that way I pass the peak on opening and closing and believe P-body does the same thing iirc.......
Re: Cam choice for 505 to run 10.50's [Re: tex013] #2006042
02/05/16 01:17 PM
02/05/16 01:17 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Tex
Thanks for the kind words. And I love your car and how good it runs now. I am sure its gonna run real strong with your new combo. up Dwayne is a good guy and will treat you right. Ron
Re: Cam choice for 505 to run 10.50's [Re: tex013] #2006052
02/05/16 01:42 PM
02/05/16 01:42 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
If this combo goes 10.50 I will be impressed. Good luck to you.
Doug
Page 1 of 4 1 2 3 4
