Duster dome light. One last try. #2005000
02/03/16 07:41 PM
02/03/16 07:41 PM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
Bought a 73 Duster and for the life of me can't get the dome light to work. I do not have power at the socket. Both doors open, both closed closed, dimmer on/off. No fuses are popped. The car is an 80k untouched car. So I have a nice untouched harness. I've looked at a diagram but still doesn't really help me.
Re: Duster dome light. One last try. [Re: da50r] #2005008
02/03/16 08:00 PM
02/03/16 08:00 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The dome light should always have power on the pink wire. It comes straight from the fuse box through a some connectors. All the switches (dome light part of the head light switch and door switches) do is connect ground.
Re: Duster dome light. One last try. [Re: Jim_Lusk] #2005028
02/03/16 08:40 PM
02/03/16 08:40 PM
go behind the DR kick panel and the pink wire should be hot all the time. I'm sure you have checked the dome light fuse & it goes out from the fuse box to the kick panel. You can also ohm the downstream yellow/pink wires there (which go to the dome light) & there should/must be continuity
Re: Duster dome light. One last try. [Re: da50r] #2005165
02/03/16 11:31 PM
02/03/16 11:31 PM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
I pulled the dome socket out today. It's got two black wires that run to the dome. They look to be factory and untouched.
Re: Duster dome light. One last try. [Re: da50r] #2005166
02/03/16 11:33 PM
02/03/16 11:33 PM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
Also, somebody has disconnected what I believe to be the key in buzzer. They suggested that might be part of the dome power. Is this correct? I'd like to hook it back up. However I'm not positive that it's the buzzer. It's the yellow "box".
Re: Duster dome light. One last try. [Re: da50r] #2005176
02/03/16 11:48 PM
02/03/16 11:48 PM
md
mopars4ever Offline
mopars4ever  Offline
md
There is a lights on buzzer shown at the bottom of the diagram.
Re: Duster dome light. One last try. [Re: da50r] #2005185
02/03/16 11:56 PM
02/03/16 11:56 PM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
Just an update. I hooked up the stray wire and the key in buzzer was sounding off. The door switch would shut it off. So that gives me faith that the door switch is ok at least. Man that thing is annoying.
Re: Duster dome light. One last try. [Re: da50r] #2005195
02/04/16 12:06 AM
02/04/16 12:06 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Have you pulled the driver's side kick panel, as someone mentioned? Cause there is a connection there and like that is what got pulled loose.
Don't be the exception.
Re: Duster dome light. One last try. [Re: da50r] #2005199
02/04/16 12:11 AM
02/04/16 12:11 AM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
Yes. I don't see anything disconnected. I will run a continuity check tomorrow to see if I can verify the wires to the dome light are not broken somewhere. Thanks a lot guys. I appreciate the replies.
Re: Duster dome light. One last try. [Re: da50r] #2005261
02/04/16 01:34 AM
02/04/16 01:34 AM
keep in mind that the dome bulb has dual contacts & that the bulb metal perimeter housing does not ground the bulb like a 1157 brake/taillight bulb does. one wire from one of the bulb base contacts (supposed to be the yellow one/not sure why yours are black) goes down & T's (twice) so that either door or the HL switch can (potentially) ground it out to complete that circuit
Re: Duster dome light. One last try. [Re: da50r] #2005275
02/04/16 01:54 AM
02/04/16 01:54 AM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
I will pull it back apart tomorrow. I'm positive those wires are black. Which is strange indeed. I've never owned or worked on a Duster, just my darts. However, there a larger circle imprinted in the headliner. It's a perfect circle, but it's about 6-8" diameter. It looks more molded than like an aftermarket dome was mounted. But I found it strange that there is a circle in the headliner around the factory dome aluminum base. Is that just a design feature or am I looking at something way way deeper??
Re: Duster dome light. One last try. [Re: da50r] #2005287
02/04/16 02:11 AM
02/04/16 02:11 AM
The one I owned was decades ago & I cant remember back that far. It is classed as a Valiant. yeah dig in when you can/grab your VOM & holler back when you can
Re: Duster dome light. One last try. [Re: da50r] #2005294
02/04/16 02:18 AM
02/04/16 02:18 AM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
I'm not convinced the original owner didn't mess with the fixture and wiring now. Two black wires, not pink and yellow... Ring around the fixture as evidence that there was a different style some light installed at one point.... I'm at an investigating stopping point.
Re: Duster dome light. One last try. [Re: da50r] #2005392
02/04/16 12:36 PM
02/04/16 12:36 PM
Seaford Delaware
JSR1485 Offline
JSR1485  Offline
Seaford Delaware
The wires that go directly to the dome light are black or black & brown, they connect to a plug on the drives side either roof pillar area in 1/4 or behind the rear seat on the frame work. The wire is pink to that connector. If you pull ether kick panel out, you can see the connector that plug into the door switch and as stated before it should be hot all the time.
Switched to the dark side...
Re: Duster dome light. One last try. [Re: da50r] #2005399
02/04/16 12:45 PM
02/04/16 12:45 PM
Maryland
reno340 Offline
reno340  Offline
Maryland
They all have that ring in the cardboard headliner. it is stamped in. I think yours is still untouched.
"There are only three real sports, Mountain climbing, Bull Fighting and Auto Racing. The rest are just games"
- Earnest Hemmingway
If you can't run with the big dogs, stay on the porch!!
https://www.youtube.com/watch?v=_xQJtN1_6DU
Re: Duster dome light. One last try. [Re: da50r] #2005400
02/04/16 12:47 PM
02/04/16 12:47 PM
md
mopars4ever Offline
mopars4ever  Offline
md
It was quite a few years ago when I messed with my duster. From memory my 73 was like JSR said. My connector was in the drivers side rear roof pillar quarter panel area. The evidence you see could have been someone trying a different dome lamp out in a attempt to fix it. The original housing is round. I believe the color wires you have are correct.
Re: Duster dome light. One last try. [Re: da50r] #2005455
02/04/16 02:44 PM
02/04/16 02:44 PM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
I pulled the kick panel this morning. The plug has the pink wire hot on both sides of the plug. It's hot all the way back to the back of the door. I chased it as far as I could before pulling the rear interior apart. No matter what I did to the door switch or dimmer switch, it was always hot. I wonder what all I need to pull to continue to chase it ? Thanks.
Re: Duster dome light. One last try. [Re: da50r] #2005487
02/04/16 03:26 PM
02/04/16 03:26 PM
OK we have fire to the kick panel for the dome (the pink wire). we need continuity from there to the bulb and continuity back from the bulb back to the door sw's/HL switch. Dont know if that helps
Re: Duster dome light. One last try. [Re: da50r] #2005497
02/04/16 03:37 PM
02/04/16 03:37 PM
Seaford Delaware
JSR1485 Offline
JSR1485  Offline
Seaford Delaware
Take a test light and see if you have power @ the dome light in the center , test your ground on your test light and make sure you have a good ground first. A trim screw on a interior molding usually works good.
Just a FYI- I have had china made bulbs not work and go pull an old american made bulb and install and it works.
Re: Duster dome light. One last try. [Re: da50r] #2005532
02/04/16 04:39 PM
02/04/16 04:39 PM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
Roger that. I got a good ground. I have confirmed no power at the actual wire behind the dome socket. That rules out a bad socket too. I've got power back to the back of the door. I popped the door sill off and pulled the channel back. I was able to get down there and stick the pink wire. I hate poking tiny pricks in wiring but that was the only way I could check it. So we are live back to just behind the drivers door down in the channel. I just learned that there is possibly a plug that is the pink wire to the black wires for the plug in the LR wheel house area. When I get a chance I'll go verify that. I'm just trying to chase it as close to the dome as possible. Thanks all.
