Re: Last day of '70 E-body production?
[Re: formula_s]
#2005139
02/03/16 11:17 PM
02/03/16 11:17 PM
Posts: 138 CO
ihv800
CO
My 7/30 built fk5 cuda has a vin ending 438707. It has several anomalies,71 hood hinges,71 style round black vent knobs and the door jamb sticker reads H1B, apparently the keypunch operator was asleep at the job. The citron mist cuda with the mod top also had a date of 7/30. Interesting, I can't say on the hood hinges of the car in question right now, but it does have '70 vent knobs. The VIN is also a bit higher, though that doesn't necessarily mean much. I do know the passenger fender has the notch cut in it, I do not know if it's original to the car.
[Re: plumcrazycuda]
#2005149
02/03/16 11:22 PM
02/03/16 11:22 PM
Posts: 29,654 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
How many could they put out in a day back then? Approximately 1300 or so a day at Hamtramck. The highest VIN I have heard of from there so far is in the 4435xx range, but as stated above it would take a whole lot of information to try to determine which car was last off the line. (Number edited due to dyslexic moment.)
[Re: Alaskan_TA]
#2005544
02/04/16 05:07 PM
02/04/16 05:07 PM
Posts: 138 CO
ihv800
CO
The highest VIN I have heard of from there so far is in the 3445xx range I might be missing something, but I'm not sure I follow? That seems like a pretty low number? What was different on the 1971 hood hinges, besides I gather they used a 3/8th bolt to mount the hood? What other '71 features might be present on a very late '70 car?
[Re: ihv800]
#2005606
02/04/16 07:24 PM
02/04/16 07:24 PM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
That seems like a pretty low number? Edited above, I typed the 3 in the wrong spot.
[Re: 6bblgt]
#2005840
02/05/16 12:43 AM
02/05/16 12:43 AM
Posts: 657 B.C.
mk_
B.C.
yes, the changeover to the "1971" style hinge would've been a running change during the 1970 model year - they were necessary with the introduction of "crush zone" hoods. IIRC the STANDARD 'Cuda "RALLYE HOOD" started changeover in April of '70.
"1970" hoods w/NO "crush zone" with 5/16" bolts (1/2" head) VS. "1971" hoods w/"crush zone" with 3/8" (9/16" head) with related slots in the hood hinges.
FWIW 'Cuda SHAKER hoods didn't "changeover" 'til mid-1971 model year I have a 70 Cuda with a build date of 4 01 and it has a rally hood with the crush zones and 5/16" hood hinge bolts.
[Re: mk_]
#2006131
02/05/16 03:46 PM
02/05/16 03:46 PM
Posts: 1,747 PA
plumcrazycuda
PA
FWIW 'Cuda SHAKER hoods didn't "changeover" 'til mid-1971 model year I have a 70 Cuda with a build date of 4 01 and it has a rally hood with the crush zones and 5/16" hood hinge bolts. Are you saying that 71 hood hinges won't work on a 70 no crush zone hood? The reson I am asking is I need to get a set ready for my Cuda and will be using a no crush zone hood. Like to use the hinges that came off my car
[Re: ihv800]
#2006308
02/05/16 09:09 PM
02/05/16 09:09 PM
Posts: 406 California City, CA
dart440
California City, CA
As stated above, the bolt size might be different (and thus you might have the smaller slots in the hinge for the smaller bolt size).
Easy check by trying the correct bolt size for the hood and see if it fits in the corresponding slot of the hood hinge. If too small, you should be able to open up the slots slightly to fit the larger diameter bolts.
Late production cars can be a mix-mash of both year parts. I have a 6/30 built 71 Barracuda with the 72-up style driver's side inner fender (has the later style battery hold-down).
When you work on Spaceships for a living, how bad can a workday be?
