Re: Help Disengaging Front Torsion Bars from K-Member [Re: 64Post] #2004958
02/03/16 05:52 PM
02/03/16 05:52 PM
Mass.
dartmadness Offline
dartmadness  Offline
Mass.
A little trick . I use a BMX alumium four bolt gooseneck that holds the handle bars on as a removal tool. Bolt it down and hit it out with a hammer.
Re: Help Disengaging Front Torsion Bars from K-Member [Re: vinnyd76] #2004975
02/03/16 06:39 PM
02/03/16 06:39 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I believe you will need to bolt the K member back onto the body before the torsion bars will come out. Both ends are in a machined housing and need to move about 2" - 3" backwards to come out. The hex on each end of the bar is also a machined surface about 1 1/2" long. Picture a nut in a deep well socket, the bar is the nut, the socket on one end is the lower control arm pivot, and the other end socket is the trans crossmember. The nuts are one piece, the ends do not give or flex. I don't believe the bars will move through the machined housings with the weight of the K member hanging on them.
The other option is to unbolt the lower control arm pivot point on both control arms and pull the K member forward off the control arm pivot points, then you may be able to remove each lower control arm off the torsion bars individually. Once the control arms are removed from the bars, they will probably come out of the trans crossmember.
When you reassemble it, install everything except the torsion bar adjusting bolts, be sure the control arms are pointing down, then install the bars, then the adjusting bolts. If the control arm torsion bar sockets are not oriented correctly, the bars will bot have enough tension to support the car. Gene
Re: Help Disengaging Front Torsion Bars from K-Member [Re: vinnyd76] #2005027
02/03/16 08:39 PM
02/03/16 08:39 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
PLEASE don't take this the wrong way but.....
you are referring to the torsion bars and not the strut rods, right?
Re: Help Disengaging Front Torsion Bars from K-Member [Re: mikemee1331] #2005047
02/03/16 08:56 PM
02/03/16 08:56 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Yes, I' m referring to the torsion bars.
Re: Help Disengaging Front Torsion Bars from K-Member [Re: vinnyd76] #2005249
02/04/16 01:17 AM
02/04/16 01:17 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Normally, the torsion bars are the first thing I remove. As mentioned, you need to bolt the K member back up. You'll never get the bars out with the bind you have them in. twocents
Re: Help Disengaging Front Torsion Bars from K-Member [Re: 64Post] #2005529
02/04/16 04:21 PM
02/04/16 04:21 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
^^ This.
Re: Help Disengaging Front Torsion Bars from K-Member [Re: pushbutton] #2006040
02/05/16 01:12 PM
02/05/16 01:12 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Once again, thank you for the feedback!
I'm planning to try all the suggestions either tonight or tomorrow... it's been a busy week. I appreciate all the feedback. I will post my results once I have an opportunity to trial your suggestions.
Thanks again,
Vinny
Re: Help Disengaging Front Torsion Bars from K-Member [Re: vinnyd76] #2007054
02/06/16 11:33 PM
02/06/16 11:33 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Today, I purchased the torsion bar tool from Mancini's. I bolted the K-Member back to the body rail and installed the torsion bar assist tool. The torsion bars came out with no problem. Thank you again for all the input!
Re: Help Disengaging Front Torsion Bars from K-Member [Re: vinnyd76] #2007883
02/08/16 12:48 PM
02/08/16 12:48 PM
Albany, NY
67SATisfaction Offline
The member whose name is actually Art
Albany, NY
Here's the home made device I came up with to clamp my torsion bars so I could whack them out…. you don't want to hit or damage the bars!
Took a hell of a beating to get them loose, wore myself out with a 5lb sledge… if I did it again I'd heat up the receiving end at the subframe with a plumber's blowtorch first.
Good luck, - Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Help Disengaging Front Torsion Bars from K-Member [Re: vinnyd76] #2008035
02/08/16 05:36 PM
02/08/16 05:36 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
67SAT the wood has too much give when you hit it, your loosing 1/2 your "wackem" power! Cleaning the crud out of the receivers (both ends of the bar) helps a lot, and a little penetrating oil also helps, but sometimes you just have to show them (the T bars) who is going to win. Gene
