Re: Duster dome light. One last try.
[Re: Jim_Lusk]
#2005028
02/03/16 08:40 PM
02/03/16 08:40 PM
RapidRobert
go behind the DR kick panel and the pink wire should be hot all the time. I'm sure you have checked the dome light fuse & it goes out from the fuse box to the kick panel. You can also ohm the downstream yellow/pink wires there (which go to the dome light) & there should/must be continuity
[Re: da50r]
#2005166
02/03/16 11:33 PM
02/03/16 11:33 PM
Posts: 2,628 Middle TN
da50r
Middle TN
Also, somebody has disconnected what I believe to be the key in buzzer. They suggested that might be part of the dome power. Is this correct? I'd like to hook it back up. However I'm not positive that it's the buzzer. It's the yellow "box".
[Re: da50r]
#2005195
02/04/16 12:06 AM
02/04/16 12:06 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Have you pulled the driver's side kick panel, as someone mentioned? Cause there is a connection there and like that is what got pulled loose.
[Re: da50r]
#2005261
02/04/16 01:34 AM
02/04/16 01:34 AM
RapidRobert
keep in mind that the dome bulb has dual contacts & that the bulb metal perimeter housing does not ground the bulb like a 1157 brake/taillight bulb does. one wire from one of the bulb base contacts (supposed to be the yellow one/not sure why yours are black) goes down & T's (twice) so that either door or the HL switch can (potentially) ground it out to complete that circuit
[Re: da50r]
#2005287
02/04/16 02:11 AM
02/04/16 02:11 AM
RapidRobert
The one I owned was decades ago & I cant remember back that far. It is classed as a Valiant. yeah dig in when you can/grab your VOM & holler back when you can
[Re: da50r]
#2005392
02/04/16 12:36 PM
02/04/16 12:36 PM
Posts: 1,123 Seaford Delaware
JSR1485
Seaford Delaware
The wires that go directly to the dome light are black or black & brown, they connect to a plug on the drives side either roof pillar area in 1/4 or behind the rear seat on the frame work. The wire is pink to that connector. If you pull ether kick panel out, you can see the connector that plug into the door switch and as stated before it should be hot all the time.
Switched to the dark side...
[Re: da50r]
#2005399
02/04/16 12:45 PM
02/04/16 12:45 PM
Posts: 386 Maryland
reno340
Maryland
They all have that ring in the cardboard headliner. it is stamped in. I think yours is still untouched.
"There are only three real sports, Mountain climbing, Bull Fighting and Auto Racing. The rest are just games" - Earnest Hemmingway If you can't run with the big dogs, stay on the porch!! https://www.youtube.com/watch?v=_xQJtN1_6DU
[Re: da50r]
#2005487
02/04/16 03:26 PM
02/04/16 03:26 PM
RapidRobert
OK we have fire to the kick panel for the dome (the pink wire). we need continuity from there to the bulb and continuity back from the bulb back to the door sw's/HL switch. Dont know if that helps
[Re: da50r]
#2005497
02/04/16 03:37 PM
02/04/16 03:37 PM
JSR1485
Seaford Delaware
Take a test light and see if you have power @ the dome light in the center , test your ground on your test light and make sure you have a good ground first. A trim screw on a interior molding usually works good.
Just a FYI- I have had china made bulbs not work and go pull an old american made bulb and install and it works.
[Re: da50r]
#2005906
02/05/16 02:16 AM
02/05/16 02:16 AM
RapidRobert
I think a poke into the insulation would slide past the strands (& make contact) rather than breaking one of em & when done a dab of superglue would seal up the pinprick. I have a can of some liquid plastic? stuff in a can with a brush I bought from Classic industries iirc that would do the same thing just way slower to cure/harden.
