Drum brake self-adjuster retrofit?
#2004247
02/02/16 05:00 PM
02/02/16 05:00 PM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
It's getting to be a PITA keeping a firm pedal with my front disc swap on my 67 Coronet. It came from the factory with a towing package brake setup - 11x3/11x2.5 drums. The rear axle is manual adjust only, unlike the smaller rear brake options.
I use the car recreationally a lot and having to goof with the adjusters every 4-6 weeks to get my pedal feel back up is annoying in the wet months. Are there kits I can retrofit to the 11 inch rear backing plates? I have only found kits claiming to fit cars with 10 inch or smaller rear drums.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Drum brake self-adjuster retrofit?
[Re: Secret Chimp]
#2004283
02/02/16 06:32 PM
02/02/16 06:32 PM
Posts: 25,757 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Self-adjuster kits:
RAYBESTOS H2545 Professional Grade; Wheel Kit Fits Rear Right; 11" Brakes Or Front Right; 11" Brakes
RAYBESTOS H2544 Professional Grade Fits Rear Left; 11" Brakes Or Front Left; 11" Brakes
[Re: Secret Chimp]
#2004949
02/03/16 05:32 PM
02/03/16 05:32 PM
Secret Chimp
Eugene, Oregon
I wondered if it were really that simple... I've only ever owned one Mopar so I assume everything is a little more complicated to source off the bat until I learn otherwise Thanks for confirming, I got a couple of those kits on the way to me now.
[Re: Secret Chimp]
#2005462
02/04/16 02:54 PM
02/04/16 02:54 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
My '69 Coronet R/T had the same issue. I got the parts for the 1970 B-Body which had self-adjusters on the 11" rear drum brakes. You will need the star wheels, adjuster lever, adjuster lever spring, cables and cable guides.
I think these kits have what you need?
https://www.rockauto.com/en/catalog/dodge,1970,coronet,7.2l+440cid+v8,1496006,brake/wheel+hub,drum+brake+self+adjuster+repair+kit,1904
