Instument cluster voltage limiter #2003513
02/01/16 04:35 PM
02/01/16 04:35 PM
south central nebraska
GI Moparman Offline OP
Where do I get one of the solid state voltage limiters? Ive been looking every where but the right place I guess. Needing it for a 64 Polara. Thanks
Re: Instument cluster voltage limiter [Re: GI Moparman] #2003555
02/01/16 05:22 PM
02/01/16 05:22 PM
NC
1970A66 Offline
1970A66  Offline
NC
RT-eng is where you want to get it from. He sells on his website and on ebay:
http://www.ebay.com/itm/Solid-State-Mopa...=item258f9ac75f
Here is his website:
http://rt-eng.com/rte/index.php/RTE_limiter
You need the IVR3 model according to the second link I posted.
Under "Buy IVR3" just below the "View Cart" tab you can click on "Which Cars Use The IVR3". Your Polara is listed.
Re: Instument cluster voltage limiter [Re: 1970A66] #2003682
02/01/16 08:19 PM
02/01/16 08:19 PM
Thanks ill give them a try!!
Re: Instument cluster voltage limiter [Re: GI Moparman] #2008374
02/09/16 02:03 AM
02/09/16 02:03 AM
chicago suburbs
68charger/t Offline
68charger/t  Offline
chicago suburbs
We restore all Mopar dashes, wiring harnesses, cluster parts, and trim pieces. We install our own solid state limiters or those from "rt-eng" in all the clusters that we refurbish. If interested contact us at: scott@eseandassociates.com
Re: Instument cluster voltage limiter [Re: GI Moparman] #2008447
02/09/16 10:59 AM
02/09/16 10:59 AM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
I've built a few of these and installed them. Very simple and easy to do, and dirt cheap. I bought parts to build two last time for around $10-15.
voltage limiter build
