Re: ProForged Fast Ratio Pitman and Idler Arm Kit
[Re: Devil]
#2003663
02/01/16 07:47 PM
02/01/16 07:47 PM
Posts: 2,432 NorCal
RylisPro
NorCal
I have read that the ProForged stuff is made overseas. Have also read that Hotchkis stuff is Made in USA. If they look alike so who knows where they are really made, maybe Jon or Dan can chime in? I run the Firm Feel Fast Ratio stuff & idler bearing kit on my E-Body and I can confirm for a fact that they do not hit a LA small block on stock mounts with Hedman D453 1-5/8" headers or a Gen 3 Hemi w/ Schumacher mounts and TTI 61HC 1-3/4" headers America!
[Re: Devil]
#2014059
02/17/16 04:54 PM
02/17/16 04:54 PM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
ProForged = made in Taiwan. Good quality control.
Hotchkis = uses proforged ball joints, etc, in their kits. Hotchkis switched to proforged because they are better than current production moog. I don't know about the pitman and idler specifically, would make sense they are proforged as well.
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: Devil]
#2014641
02/18/16 02:10 PM
02/18/16 02:10 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
I'm also interested in the Borgenson ps box with the longer fast-ratio arms... lighter weight (less ~15 pounds), fatser steering ratio (I' thought it becomes ~11.7:1... T/A = 12.7:1).
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Devil]
#2015200
02/19/16 02:33 AM
02/19/16 02:33 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I use a 13.6" steering wheel and I think its perfect with stock arms. I can navigate cones with one hand on the shifter, I know....bad technique.
Mopar to the bone!!!
[Re: 72Swinger]
#2015338
02/19/16 11:59 AM
02/19/16 11:59 AM
Posts: 16,158 Mesa, Arizona
dart4forte
Mesa, Arizona
I ran the Firm Feel fast ratio pitman and matching idler on my 71RR. The only problem I had was the grease zerk hitting the exhaust pipe. I was running TTI exhaust off the stock Magnum manifolds. What I ended up doing is taking a torch with a rosebud, heating that portion of the pipe, placing a 1/2" pipe over the spot and dimpling in that portion of the pipe until the zerk cleared.
I should note I was running the Firm Feel Stage II box with the fast ratio pitman. It was just a little too fast for my tastes for a street car.
Abe Lincoln
[Re: dart4forte]
#2015371
02/19/16 12:34 PM
02/19/16 12:34 PM
Posts: 2,432 NorCal
RylisPro
NorCal
I should note I was running the Firm Feel Stage II box with the fast ratio pitman. It was just a little too fast for my tastes for a street car. I have the exact same setup and it feels great! I would guess it would also depend on how wide your front tires are?
[Re: RylisPro]
#2015376
02/19/16 12:39 PM
02/19/16 12:39 PM
dart4forte
Mesa, Arizona
I should note I was running the Firm Feel Stage II box with the fast ratio pitman. It was just a little too fast for my tastes for a street car. I have the exact same setup and it feels great! I would guess it would also depend on how wide your front tires are? I had 245/60/15 on the front. Pretty much street tire
Abe Lincoln
[Re: dart4forte]
#2015433
02/19/16 02:19 PM
02/19/16 02:19 PM
Posts: 2,432 NorCal
RylisPro
NorCal
I had 245/60/15 on the front. Pretty much street tire Yup exactly what I was thinking as that size tire is on the narrow side. I would venture a guess that 275 or wider tires would feel different.
[Re: Devil]
#2015544
02/19/16 05:18 PM
02/19/16 05:18 PM
Posts: 1,491 Lethbridge, AB, Canada
dangina
I have the fast ratio arms, idler bearing kit, boregson box and a 350mm steering wheel, its 1.7 turns lock to lock, I can chime in how it is when i get to drive it this summer, I also bought the flow control valve for the power steering pump so it won't be as twitchy
[Re: RylisPro]
#2016082
02/20/16 03:17 PM
02/20/16 03:17 PM
dart4forte
Mesa, Arizona
I had 245/60/15 on the front. Pretty much street tire Yup exactly what I was thinking as that size tire is on the narrow side. I would venture a guess that 275 or wider tires would feel different. The problem when I owned the car was it was strictly street driven and totally restored. 275s would of required some sheet metal work to the front wheel openings. It had 275s in the rear on a 9" rally wheel. In addition the car was lowered from the stock height about 1". Car is gone now to a new owner so water under the bridge.
Abe Lincoln
[Re: dangina]
#2018250
02/23/16 07:49 PM
02/23/16 07:49 PM
Mopar Mitch
DANGINA -- Your setup (borgsn box and fast-ratio long arms) will be extremely interesting to hear of the results, etc.
Question: You say its 1.7 turns lock-to-lock... isn't that regardless of the long arms? So, even without the long arms, its still 1.7 turns lock-to-lock? That's very, very fast to begin with. I wonder what vehicle the borgsn ps box was originally from? Jeep? Mustang? ??? I heard, if correct, the original borgns ps box was from a Jeep... then the later model is from a Mustang (year, etc???)
The factory standard Mopar ps box is 3.5 turns lock-to-lock; the T/A ps box is 2.7 turns lock-to-lock (due to having internal stops within the box). So, the borgsn ps box with 1.7 turns lock-to-lock should be very much faster for steering respons! Only hope that, at hi-rpm competition (slaloms L/R/L/R/L/R etc) that the power assist can keep up with the driver's needed reactions,... not falling off as the Federal ps pumps all do.
Keep us posted, please!!!
Mopar Mitch
[Re: Mopar Mitch]
#2019430
02/25/16 01:32 PM
02/25/16 01:32 PM
dangina
Keep us posted, please!!! Yeah 1.7, seems quick but I've also been reading on protouring.com, that some of those early firebird/camaros are running the same 1.7 turns lock-to-lock and even they want it to be more quicker! you bet mitch, I should be driving it this spring/summer whenever i get the car back from color sand/clear coat There is also one other guy on these boards that run the exact setup as me, he is the one that told me to get the reducing valve for the ps pump as it was too "twitchy" with the stock one in
[Re: dangina]
#2019574
02/25/16 05:09 PM
02/25/16 05:09 PM
Mopar Mitch
Actually, I've never heard or seen a factory ps box from any car with less than 2-turns lock-to-lock. to my knowledge, the earlier GM f-bodies (gen-1,-2 and -3, perhaps -4 and -5) had ~2.5 turns lock-to-lock as their quickest offerings in the performance models (TransAms, Z28, SS, etc).... I don't know about the later model Mustangs as to what their lock-to-locks are.
I know the AMC guys would install GM ps boxes into their Javelins and AMX cars for faster autocrossing.
For whipping through slaloms, the less turns lock-to-lock.. the quicker reactions for maneuvers available... potential reduced E-Ts.
Mopar Mitch
